Just finished boosting my b18b 98 ls, need to install this catch can before I go get tuned in a couple days, I'm very confused cause I've heard and read so many different things about catch cans, breathers, catch can with breather(which I have)
I found this diagram, but am having trouble understanding it. Would it still work even though my catch can has a breather?
Where is the "pcv valve port, and the OEM PCV system Vaccum Source" specifically, any pics?
2 lines from the back of the block to the can with special M28 to -10 AN fittings, don't know what's going on with your set up but the way I listed is the correct way. Then you use a special plug to block off the old pcv hole where the box went plm sells a kit with everything needed or crapworks aka BWR, what's pictured looks like a half *** joke.
You were compidant enough to install a turbocharger system to your factory n.a engine and you dont know how to install a aftermarket catch can and elimate the engines oem pcv system?
Dont worrie im just giving you a hard time. Is the engine tuned? how much boost you running? might not even need one if your on low boost. It will help but theres many boosted B series still using the oem pcv system. I believe on your ls theres one directly on top of the valve cover with a hose going to the intake manifold. And on the back of the block there should be a charcoal canister or black box with a pcv valve.
I ran a modified black box setup with a gutted pcv to a filtered catch up to the valve cover. Simple and efficient for my car and yea I always run filtered catch cans on my cars this way and just use the manifold bung for my boost gauge
I got down under the car today ready to install the fittings and the catch can, and there was NO black box? As far as I could tell, I thought it was supposed to be to the right of the oil filter, but nothing was there and the holes were plugged, am I in the right spot? I tried to label the holes.
Is that the right place, and is the lower plug already filled?
I made a drawing of a pic I found, do I do something like this?
In the very bottom photo the hole circled to the right is where the box is located
There are a few different ways of doing a catch can and the bottom pic is one. Also remember to put the catch can at the highest point possible aka the passengers side strut tower or firewall
My apologies I am so used to dealing with Vtec based engines I forgot you have an LS IIRC b18 and b20 non vtec blocks do not have a catch can like D series / B series VTEC. you can still use those large allen freeze plugs as ports that I was refering to earlier....you are already set on your catch can setup as far as hardware correct? if not I recomend checking out B N R fittings he has some nice stuff, sells mostly complete solutions as far as getting everything you need in a kit. the guy is real cool to Very helpful he will answer your questions if you just call him up.
Your block should look something like this, the "freeze" plugs are on either side of the oil filter.
I've only dealt with b16 and mostly d16 so I'm used to the black box and assumed all these motors had them. Well I learned something today. Wonder why it's on the non vtec d16y7 but not on other non vtecs?
Ah that makes more sense, I'm guessing my PCV is in the middle of the valve cover from what it looks like, since there is no black box. What if I just did something like this:
Looks like the guy deleted his little PCV valve on the valve cover and just put an aftermarket L fitting there. Would this work?
P.S it is a b18b 98 LS you're right
That should work just fine. only difference with that is you are using smaller hoses then most would use. whats your HP goal again? anything under 400 should be fine. I am also going to vent my valve cover rather then the back of the block using BNR kit with 10 AN Hoses.
The car makes 280 at the wheels right now and 260 tq on 13 pounds with no timing used, just breaking in the new parts and clutch, then 350-400 tops is my goal.
So do I plug the nipple on my intake pipe that is right after the filter and before the compressor housing on the turbo?
The car makes 280 at the wheels right now and 260 tq just breaking in the new parts and clutch, then 350-400 is my goal.
sounds good if you wanted to run a larger diameter hose your welding bungs into your valve cover or going to the back of the block. yes you plug that that would only be used if you are using a vaccum source for your catch can, which would be a different style can like the one you posted on your first post
What you want is vacuum on either of the catch cans at all times. When you're not in boost, and when you're boosting. You can aid the removal of gasses on the valve cover vent by using a slash-cut hose and the ventrelli effect (air passing by the end of a hose will cause negative pressure on the other end of the hose).
So. You want 2 catch cans. Neither of them should be vented!!!
Remove the black box on the back of the block. All it does is recirculate the contaminated oil back into your oil pan (mixed with gasoline). When you remove the black box, you will require 1 freeze plug to plug the hole it will leave, approx 1 to 1 1/2 inch diameter.
The 'hose nipple' that protrudes from the back of the engine block above that freeze plug, goes into catch can 1.
Catch can 1 has 2 hoses attached. 1 feeds from nipple on back of block, other feeds thru PCV valve (or any 1 way-check valve), and then to the intake manifold AFTER the throttle plate. This can will see vac when not in boost.
Catch can 2 has 2 hoses attached. 1 feeds from valve cover nipple. The other hose goes to the intake of the turbo BEFORE the turbo. IE. where your airfilter or small stub of piping feeds into the cold side of the turbo, going into the turbo intake. This line DOES NOT want to see pressure or "true" vacuum. This is what will be the ventrelli effect line. This can will see vac when you are in boost.
Now you have a system that pulls air at all time...
If you use a vented catch can, you are relying on pressures to push the gas out. The best way, is to suck it out. Hard core drag racers use an electric sump to put constant vac on the block, removing drag on the pistons...
Make this simple. Make your setup like the last picture in the lot of 4.. Then throw a good flowing filter on the valve cover. Quick install and efficient for your power
