Car stutters while crusing?
Old Jul 26, 2008 | 10:05 AM
visine's Avatar
Default Car stutters while crusing?
When I'm on the highway doing any speed 60,65,70... with 10%-15% throttle the car will stutter and shake (not violently) and when I try to accelerate it makes a slight '2 step' sound but if I accelerate through it, its fine.
Did a tune up- oil, plugs (yes, gapped) and still same result
Old Jul 26, 2008 | 10:41 AM
hotimportcrx's Avatar
Default Re: Car stutters while crusing? (visine)
What are you using to tune it with? Some older programs, such as uberdata, dont have IAT correction so you need to retune every winter/summer. Maybe at half throttle your running lean. Did this just happen out of nowhere? If so, Tps could be taking a dump. Setup, etc?
Old Jul 26, 2008 | 11:38 AM
visine's Avatar
Default Re: Car stutters while crusing? (hotimportcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">What are you using to tune it with? Some older programs, such as uberdata, dont have IAT correction so you need to retune every winter/summer. Maybe at half throttle your running lean. Did this just happen out of nowhere? If so, Tps could be taking a dump. Setup, etc? </TD></TR></TABLE>
its tuned on s200b, yeah kinda happened out of nowhere
Modified by visine at 1:48 PM 7/29/2008
Old Jul 26, 2008 | 01:46 PM
SovXietday's Avatar
Probably getting a little lean. I take it no wideband?
Old Jul 26, 2008 | 02:59 PM
MJobe's Avatar
Default Re: Car stutters while crusing? (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">Probably getting a little lean. I take it no wideband?</TD></TR></TABLE>
I was thinking the same thing
Old Jul 26, 2008 | 03:15 PM
TheShodan's Avatar
Moderator
Default Re: Car stutters while crusing? (MJobe)
Sounds like it may need to go back to the tuner to smooth out the data tables. This can happen a lot when tuning at certain RPMs.
Old Jul 28, 2008 | 06:32 PM
CoreyR's Avatar
Default Re: Car stutters while crusing? (TheShodan)
i had a similar problem, car wasnt throwing any codes then one day i unhooked the o2 for some reason and and it stopped doing it.
Old Jul 28, 2008 | 06:52 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Car stutters while crusing? (CoreyR)
simple steps first.....check your spark plug wires. makes sure they are actually connecting to the spark plug.
Old Jul 28, 2008 | 09:24 PM
TurbodTegSfaria's Avatar
id check for a misfire first
Old Jul 29, 2008 | 11:19 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Car stutters while crusing? (TurbodTegSfaria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbodTegSfaria &raquo;</TD></TR><TR><TD CLASS="quote">id check for a misfire first </TD></TR></TABLE>
yeah that was eaiser to say than what i said.
Old Jul 29, 2008 | 12:20 PM
sweetfwdthunder's Avatar
My car started doing the same thing out of the blue one day... One of the wires going to my o2 sensor was barely coming out of the connector, but it was just enough to lose a connection, causing it to run like rotten ballz.
gt35rSI
Mar 29, 2008 08:25 PM
200TS EC
Dec 16, 2007 10:21 AM
SovXietday
Feb 27, 2007 03:49 PM
tankdogg08
May 9, 2005 12:02 PM
