car sputtering b4 boost
Old Oct 2, 2004 | 08:54 PM
Integspeed21's Avatar
Default car sputtering b4 boost
I have searched and found nothing on my problem. Ok My car is sputtering when i give it some gas and it will start jerking a little. I have replaced the spark plugs there new NGK -11's Plug wires are almost new. Fuel wise I am running of off a FMU and a inline fuel pump all lines seem to be fine. The fpr is a B&M. Stock injectors. I only seem to have this problem when I boost alot im boosting at 7psi. The Turbo is a Drag 3 kit 38mm Tail wastegate. ( It only sputters until it reaches boost levels)
Old Oct 2, 2004 | 08:58 PM
tegon-gsr's Avatar
Default Re: car sputtering b4 boost (Integspeed21)
it sounds like sometype of fuel problem i couldnt see it being anything else maybe your feul mang. but that sounds funny? free bump????
Old Oct 2, 2004 | 09:04 PM
Default Re: car sputtering b4 boost (tegon-gsr)
Thats what im wondering but how can I fix this problem and is it safe to drive my car? It only starts happining when I start boosting hard then start driving normal
Old Oct 2, 2004 | 09:52 PM
turboteg2nv's Avatar
what is your fuel pressure at? sounds like you are bogging the engine with too much gas, and then when you hit boost the engine consumes it all so it runs normal. get it tuned, ditch the FMU
Old Oct 3, 2004 | 12:06 AM
96-EJ6 B18C's Avatar
Default Re: car sputtering b4 boost (turboteg2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv &raquo;</TD></TR><TR><TD CLASS="quote"> get it tuned, ditch the FMU</TD></TR></TABLE>
Ditto. Look in to uberdata or something similar or a Hondata if you can afford it and a set of injectors. Tuning will make all the difference in the world.
Old Oct 3, 2004 | 12:48 AM
reaction360's Avatar
Default Re: car sputtering b4 boost (96-EJ6 B18C)
i'd check connections on the fmu. what fuel psi are u running at? and I'd also recommending gettin rid of the fmu and go with larger injectors and some sort of ems.
EGkid
May 12, 2005 09:04 AM
eGeeHaTcH
Jan 16, 2005 02:43 PM
SOHC_power
Oct 30, 2002 10:10 AM
SOHC_power
Oct 30, 2002 03:43 AM
HondaCutter
Sep 25, 2002 08:59 PM
