car smoking
Old Aug 19, 2011 | 08:53 PM
  #26
EsotericImage's Avatar
Retired Moderator
Default Re: car smoking
Now for the break in. Try to vary the revs as much as possible, with alot of short blasts. It is very important that you let the engine "brake" itself by just letting off the throttle and letting the vehicle slow down on it's own, while in gear. This creates a vaccum in the cylinder and forces the rings outward, which wears down the peaks in the cylinder's fresh hone. Do this for the first 20 miles, and then proceed to beat the **** out of the motor, up to it's maximum rev range, as long as it is tuned accordingly. As long as the bearings are within spec and the rod bolts were torqued correctly, there is NOTHING to worry about.
I guarantee you WILL NOT burn oil using this break in method. If you do, you probably have leaky valve seals or bad rings/cylinder hone, or maybe possibly even other major problems with alignment of the sleeves themselves.
Old Aug 19, 2011 | 09:02 PM
  #27
Spoolinls's Avatar
Ok thanks when we did the new rings we put them in painted the car drove it twice and then took it to the dyno to get tuned
Old Aug 19, 2011 | 09:09 PM
  #28
Spoolinls's Avatar
Today u pulled some hoses off to replace and there is no thermostat wounder if that's wat its causing
dsturch1
Mar 25, 2008 06:16 PM
FONK
Sep 20, 2005 09:57 AM
Nikoli
May 30, 2004 07:31 AM
RTW DC2R
Apr 6, 2004 08:08 PM
