Car smokes??? Help
Old Sep 6, 2002 | 05:20 PM
DRAGLS's Avatar
Default Car smokes??? Help
I just rebuilt my b18b 367 miles ago when i come from a stop it lets out a puff of smoke my buddy says that's because the rings aren't fully seated any opinions or suggestions also when i remove the spark plugs there is a coat of oil on the piston tops??????
Old Sep 6, 2002 | 05:26 PM
DIRep972's Avatar
Smarter than you
Default Re: Car smokes??? Help (DRAGLS)
I agree w/ ur buddie. but they should have seated by now. i would think.
did u rebuild with stock parts?
[Modified by DIRep972, 5:23 AM 9/7/2002]
Old Sep 6, 2002 | 05:29 PM
DRAGLS's Avatar
Default Re: Car smokes??? Help (DIRep972)
no ross pistons and eagle rods and (total seal rings(i don't want to hear it)
Old Sep 6, 2002 | 05:38 PM
Jared's Avatar
I know you dont want to hear it, but i bet its those total seal rings. pull the head off, rehone, and throw in a good set of rings, then go seat those bad boys.
Old Sep 8, 2002 | 05:45 AM
DA666's Avatar
Default Re: Car smokes??? Help (Jared)
what to go with other than total seal?
curious
Old Sep 8, 2002 | 06:40 AM
DRAGLS's Avatar
Hey guys do think a leak down test will really show me if its the rings.
Old Sep 8, 2002 | 06:41 AM
DRAGLS's Avatar
also what is a good ring set to go with the car sees alot of boost 16psi+
Old Sep 8, 2002 | 06:50 AM
DRAGLS's Avatar
Default Re: Car smokes??? Help (Matthew)
I am not using stock pistons i am using ross 8.5 compression pistons.
Old Sep 8, 2002 | 08:59 AM
DLB1994's Avatar
so u can still use a stock ring if u got the 81mm bore
i had total seal for about a week smoke smoke smoke the the comp test came out good its the oil ring they use it wont seal
blub16hatch
Nov 29, 2006 09:40 AM
discopotato03
Nov 6, 2004 07:44 AM
bboyoxygen
11
Nov 2, 2004 09:55 PM
JDMCRX
Jul 4, 2003 12:58 PM
7rrivera7
Mar 26, 2003 05:52 AM
