Total Seal Piston Rings
Old Mar 23, 2003 | 04:41 AM
7rrivera7's Avatar
Default Total Seal Piston Rings
Rebuilding my engine and want to know if they are worth installing on JE SRP 10.5:1's instead of the ones that come with the pistons.
Any change in compression?
Old Mar 23, 2003 | 05:15 AM
Neukin's Avatar
Default Re: Total Seal Piston Rings (7rrivera7)
endyn has some good deals eagle rods and any compression piston ( wisco pistons) with nippon ring? i belive and your wrist pins for like 900. theoldone.com
Old Mar 23, 2003 | 09:00 AM
non-VTEC's Avatar
i would go with weisco piston rings. total seal rings are good despite what many people say but you have to follow thier recommended boring and cylinder wall honeing procedure to get those rings to seat properly.
and why are you only going with 10.5:1CR?......the higher the better.......11.5:1+ is what i would go for if you are going N/A.
Old Mar 26, 2003 | 05:52 AM
GM2000ITR's Avatar
New User
Never had any luck w/ Total seals. JE rings(what should have come w/ your pistons) have never failed (for anyone I know). Jut stick with them & you'll be fine. Be sure to follow their gapping/setting procedures. Good luck!
JJDub
Engine Machining & Assembly
May 31, 2017 07:30 AM
existanzcivicb20
Sep 29, 2014 05:33 AM
zenon8890
Feb 5, 2009 06:01 PM
Mydogisgone
Mar 9, 2007 08:17 AM
siis2fast
Jun 7, 2005 03:52 AM
