car shutting off
Old Oct 1, 2002 | 12:02 PM
b18turbocivic's Avatar
Default car shotting off
Alright guys i hope you can help me out(already searched). I finally got my 440 cc injectors in and i'm running the afc hack according to the intruccions on http://www.thedropshop.tv/vafc.htm. The car was idling and running fine the first couple of days but now all of the sudden the idle is real low and when i come to a stop the car just dies. This doesnt happen all the time. I dont have any CELs so i dont have a clue of what it could be. My settings are -35(1000) and -36 on the rest. My timing is stock yet i have the BTM retard 1 degree per psi.
I dont have any idea of what might be going on ....so i hope you guys can help me ......
[Modified by b18turbocivic, 9:04 PM 10/1/2002]
[Modified by b18turbocivic, 9:05 PM 10/1/2002]
Old Oct 1, 2002 | 07:05 PM
BoostedSi's Avatar
Default Re: car shotting off (b18turbocivic)
Does it feel like its bogging? U dont have an inline pump rite? Trying leaning it out to -40 at 1000rpm
Old Oct 1, 2002 | 08:44 PM
Default Re: car shotting off (BoostedSi)
no....i don't have a inline pump but i got a upgraded intank......and yes it feels like it's bogging....so you think it's running too rich at idle??...also what should i have my puel pressure set at on my fpr....i have it at 40....maybe i should turn it down some??....anyway thanks for the reply...
[Modified by b18turbocivic, 5:45 AM 10/2/2002]
Old Oct 1, 2002 | 09:17 PM
BoostedSi's Avatar
40 static pressure isnt too high...u can just leave that. Could it be something with the map sensor?
Is it dying out because the idle is going to low? If so try adjusting the screw for the throttle body.
Did you get your injectors used? One of the injectors could be clogged...thats the only thing i can think of at the moment..good luck
Old Oct 2, 2002 | 06:28 AM
the idle is fine for a while but after a few minutes of driving starts doing it. For example if i dont **** fast enough the rpms go down and dies so i have to shift really fast for it to not die.
I got the injectors brand new from RC so i doubt they are clogged. I'll try turning up the idle at the throttle body.I'll post again and see if that fixed it....Thanks man i really apprecite the help.
RAW323
Aug 24, 2005 03:34 PM
boosted6thgen
Oct 1, 2003 08:43 AM
ITR41
Mar 30, 2003 04:54 PM
Andrew 825SM
Oct 26, 2002 08:35 PM
niedejb
Jun 29, 2002 08:43 AM
