Car is running bad..need help
New User
i have a 1993 delsol si with greddy turbo kit boosting 5.5psi. just recently the car has been sputtering when you give it gas in the low rpms. the car runs fine once the turbo is spooled. from about 2k rpms till 3 rpms the car sputters and bogs out. teh turbo has only been ont he car for about a month and i really odn't know too much about turbos so any help would be appreciated..thakns
Re: Car is running bad..need help (jesse)
First check if your FCU is hooked up properly and all the conections are soldered.
Did you change your plugs and regap them? If not try that. Use NGK brk7e plugs are try gapping them at .032
How many miles are on your car? You might need to replace your cap and rotor, I had similar problems and that worked for me.
Good Luck.
Good Luck.
New User
Are you using the blue box? If it is not connected correctly, or if a wire comes off, your car will run like crap. The way to tell if it is installed correctly is check the LED, if it blinks green you are ok, if it is dark, the wiring isn't right.
