Car Bogging
Old Jul 20, 2001 | 10:04 PM
SpeedBump's Avatar
Default Car Bogging
I just got my turbo on like two weeks ago. Civic with a gsr motor now with turbo. I just got my clutch on yesterday so I haven't gotten on it at all. But after the car gets warm it bogs in low gears. Like after stop lights it doesn't want to go. Feels like the car isn't getting something. I have the vortec fmu and an intank fuel pump. The kit didn't do this on my friends car. He had an ls and we swapped everthing over. Any ideas why it would be bogging.
Could it be vacuum lines. The car vacuums at 18 or so but right now I have the fmu, blowoff, and boost gauge all hooked up to one vacuum line. I plan on changing it tomorrow. Could this cause the car to bog. My friend thought with everything hooked up to one line it could give the fmu a bad reading and cause the car to run lean. any suggestions?
Old Jul 20, 2001 | 11:54 PM
chri5's Avatar
Default Re: Car Bogging (SpeedBump)
is it bogging at WOT or at part throttle? I it is at part throttle I doubt it would be the FMU, because that should only work when boosting. Do these runn off the same line as the fpr? What is your timing set at? Any CELs?
Old Jul 21, 2001 | 11:43 AM
FAST94GSR's Avatar
New User
might be getting too much fuel.. what is your fuel system like besides the fmu? fuel pressure?
Old Jul 21, 2001 | 06:42 PM
SpeedBump's Avatar
Default Re: Car Bogging (FAST94GSR)
It bogs at low rpms whethter full throttle or half. The fmu is on the same vacuum line as the fpr but it's the stock fpr. My buddy was running his stock fpr and it ran fine. I'm gonna try to redo some vacuum lines tomorrow. Do you guys think it could be because all my stuff is hooked up to one vacuum line?
Old Jul 21, 2001 | 11:51 PM
1FastLS's Avatar
New User
I'm having the same problem. I re-installed my turbo today and whenever I turn on the car with the in-line fuel pump, the engine bogs down. Even worse at half throttle. It seems like its the pump is getting really hot for some odd reason. I got the FMU vacuum line in line with the stock FPR. It runs fine with out the in-line fuel pump. I don't know whats wrong.
Old Jul 22, 2001 | 03:46 AM
dustin's Avatar
Default Re: Car Bogging (1FastLS)
1FastLS: you put the fuel pump in the right direction, and wired it in the right direction... right?
Dustin
Old Jul 22, 2001 | 07:48 AM
1FastLS's Avatar
New User
Default Re: Car Bogging (dustin)
The pump is wired right and its going to the right direction. I double checked, and triple checked. I even checked my FMU. Got the return line from the stock FPR going to the IN of the FMU and the OUT to the return line.
Old Jul 23, 2001 | 01:35 PM
1FastLS's Avatar
New User
I found the problem. There was a clog after FPR. Now to fix the oil leak.
JDMs1eeper
Jul 13, 2003 09:04 PM
DC2R714
Mar 7, 2003 08:50 AM
johnisenglish
Jan 13, 2003 07:02 PM
sporkcrx
Nov 1, 2002 04:43 PM
DLB1994
Sep 4, 2001 07:20 PM
