car blowing smoke
Old May 18, 2006 | 06:47 AM
wpgcivic's Avatar
Default car blowing smoke
95 gsr teg
b16 block(dont ask) gsr head
drag 3 kit
when i slow down there is a bunch of grey smoke that will pass, dont really notice it when driving. compression is 210 210 190 190
turbo maybe?
Old May 18, 2006 | 08:42 AM
Running925's Avatar
Default Re: car blowing smoke (wpgcivic)
check for shaft play.. sounds like the turbo is on the way out
Old May 18, 2006 | 09:56 AM
wpgcivic's Avatar
yeah there is some shaft play, no side to side play, my oil drain is almost horizontal think this could have caused the problem?
Old May 18, 2006 | 11:52 AM
wpgcivic's Avatar
c'mon turbo guru's, think its the turbo?
Old May 18, 2006 | 01:21 PM
Jay_Sensing's Avatar
Yep, sounds turbo ish to me. The oil drain being almost flat will cause the oil to back up in the line and it has to go somewhere.
I would take care of that first and see if the problem goes away after a few miles once it's had a chance to burn out whatever was left in there.
If not, then it is probably time to replace that thing.
Old May 18, 2006 | 02:37 PM
wpgcivic's Avatar
ok thanks for the input dude
Old May 18, 2006 | 03:08 PM
Day-DayC's Avatar
Default Re: (wpgcivic)
ive seen it before i vote turbo try straiting the return as much as possiable
Old May 19, 2006 | 05:18 AM
wpgcivic's Avatar
yeah gonna give a couple things a try today, thanks for input
prelude2perfect
Apr 30, 2010 01:09 PM
luv2boost
Jul 6, 2007 05:01 AM
ProjectEG8
Jun 19, 2007 09:59 AM
riceball777
Jun 26, 2006 06:22 PM
jdmcivic1999
Feb 12, 2005 04:05 PM
