Can't Shift gear when engine is runing?????please help
Old Aug 16, 2006 | 01:54 AM
alghafat424's Avatar
Default Can't Shift gear when engine is runing?????please help
I have the clutchmasters stage 3 in my B18B for less than 2000 miles. I am not srue if it is from the tranny or the clutch???? When the enging is not started, I can shift gears smoothly, but once I start it, it gets very stiff and it won't shift and when I force it, it will make that noise as if I wasn't using the clutch to shift.
Your help is appreciated guys.
Old Aug 16, 2006 | 02:34 AM
DaveF's Avatar
Default Re: Can't Shift gear when engine is runing?????please help (alghafat424)
try bleeding your clutch or maybe adjusting some free play out of the pedal.
Old Aug 16, 2006 | 04:56 AM
mike1114's Avatar
Default Re: Can't Shift gear when engine is runing?????please help (dturbocivic)
Like said, most likely your master cylinder or slave cylinder is going bad.....replace both.
Worst case scenario is I once had a flywheel bolt back out and it wouldn't let me shift when the car was running but it would let me shift when the car was off. It took me forever to figure out it was the flywheel bolt.
Start simple with the master and slave cylinders first.
Old Aug 16, 2006 | 05:02 AM
PM-Performance's Avatar
Default Re: Can't Shift gear when engine is runing?????please help (mike1114)
try the slave cyl first. I just had that problem though and it was cuz my disc was fuzed to the Flywheel.
Old Aug 21, 2006 | 08:31 PM
Default Re: Can't Shift gear when engine is runing?????please help (PM-Performance)
I bought after market parts for the salve cylinder which are the spring and that small piece on top pf the spring.......but unfortunatly still
I opend the tranny and the clutch was like new.....
I need your advice guys....
Should I buy the OEM parts???
Old Aug 21, 2006 | 11:27 PM
LSTEG96's Avatar
this happened to my buddies car... it turned out to be a piece of the clutch broke off... couldnt see it till u took the clutch out.
JDM-ish
Jan 20, 2007 05:52 PM
mike1114
Jul 10, 2004 06:37 PM
mike1114
Nov 18, 2003 04:38 AM
del_parker
Sep 1, 2003 07:17 PM
mike1114
Apr 28, 2003 11:12 AM
