Cant clock turbo
Old Sep 25, 2009 | 12:26 PM
beseman's Avatar
Default Cant clock turbo
I have a gt3257. I am trying to rotate the middle housing so that I can move the drain plug to a new angle. I have clocked the cold side to where it needs to go, but I cannot get the middle section to budge. I have taken all 4 screws out that hold the middle into the exhaust housing but it hasnt moved a millimeter. It almost looks like there might be different holes i can screw these bolts back into once i rotate the housing, as opposed to being able to clock it in any direction you wish. Do i need to remove the turbine itself to get this middle section to rotate or what? tia
heres a pic to help
Old Sep 25, 2009 | 02:24 PM
everythingwentblack's Avatar
Default Re: Cant clock turbo
I ran into trouble when trying to clock mine, so what I did was loosen all the screws on the exhaust side (couldn't take all of them out becuase they were hitting the actual turbo itself) and gently tapped it with a mallet. Don't swing at it (obviously) but if you tap around it in an even circular motion (like when you put cups in your headset or bottom bracket old school bmx style) it will loosen it up enough for you to hand turn it where ever you like
Old Sep 25, 2009 | 07:32 PM
beseman's Avatar
i did the rubber mallet trick with no success. are some turbo models different, where u must remove certain parts to clock it?
Old Sep 25, 2009 | 08:26 PM
91jdmhatchback's Avatar
i haven't seen a center section like that. maybe you can't clock the turbine side. normally the center section is held on bu removable tabs. not bolts through the center section.
Old Sep 26, 2009 | 12:00 AM
civic_r87111's Avatar
Ur's is probably rusted to the point it won't move, spray it with some pb blaster or liquid wrench and let it soak then try the malet thing again.
Old Sep 26, 2009 | 08:41 AM
beseman's Avatar
This is what i am begining to think too. Has anyone ever heard of one that cant be clocked? ill take better pics of it
Old Sep 26, 2009 | 09:04 AM
beseman's Avatar
is it me or does it look like there are alternate places to mount the main housing to the exhaust housing. it looks like those are even spaced threaded holes where u could pull out the housing and clock it at a few different angles. has anyone ever seen anything like this? Im feeling like I would have to disassemble the shaft to adjust it, any thoughts?
Old Sep 26, 2009 | 09:10 AM
AJxr's Avatar
i used a torch and beat the **** out of exhaust housing on my holset with a big ball peen hammer. then it moved.
sometimes you need to get rough but i wouldnt go to crazy with a nice minty turbo like yours, mine was fresh from the junkyard haha.
Old Sep 26, 2009 | 11:34 AM
beseman's Avatar
TADAAAA...........
well i was right and wrong after i kept hitting it with a hammer. I was right that there were a few different positions that I could clock the main housing, however I did not have to take the shaft apart. Im golden except for the fact that I still cant get my drain line to go to the oil pan smoothly, what do yall think?
Old Sep 26, 2009 | 02:20 PM
Flashmn's Avatar
That kink is horrible.
Old Sep 26, 2009 | 02:48 PM
srmofo's Avatar
can you cut that line a little shorter and adjust the angle on the AN fittings?
I wouldnt leave that kink in there.
Or if you have to just use straight ANs with a longer length of hose and a slightly longer arch.
Old Sep 26, 2009 | 03:09 PM
B16Drag's Avatar
Oh yes, please remove that kink.
Old Sep 26, 2009 | 05:38 PM
beseman's Avatar
I wish it was as easy as "just remove that kink"
I cant clock the turbo in infinite angles so this is the best I have been able to come up with trust me. the pictures are kinda deceiving, but those are the closest I can get the ends to being in a straight line.fml
Old Sep 26, 2009 | 05:59 PM
Just a question. how about get rid of the an fittings, and run barbed fittings. there way shorter and no one can see the bling anyway.
Old Sep 26, 2009 | 06:04 PM
Kevin's Avatar
Convert to push-lok fittings, that kink is definetly removable with the right hose setup.
Old Sep 26, 2009 | 06:16 PM
beseman's Avatar
I was not aware of these fittings. I shall look into them.thanks
Old Sep 27, 2009 | 10:43 AM
beseman's Avatar
any advice as to where to get barbed or push lock fittings and hoses? My search has yeilded little and google results are looking sketchy
Old Sep 27, 2009 | 11:24 AM
nihad's Avatar
That turbo is an older style garrett with the bolts on the housing like that i have one to.. on my 240sx.
Old Sep 27, 2009 | 12:39 PM
Look in your local phone book for places that sell tubes or hose for hydraulic lines. they will carry the fittings to go with the hoses. and thats where i get all my stuff. but if for some reason you don't want to/can't find a place. go here.
http://www.summitracing.com/search/D...b/?Ns=Rank|Asc
But i can tell you the stuff at the supply stores is WAY cheaper. and they have large selections.
shaylude01
Jun 22, 2010 11:42 AM
D15Bbigred
May 18, 2007 03:03 PM
SOHC_MShue
Apr 9, 2006 12:42 PM
TurbothisLS
Feb 19, 2004 05:53 AM
HXMan
Jan 27, 2003 07:03 PM
