can't boost beyond 12 lbs.
Old Oct 18, 2005 | 10:18 AM
vu337's Avatar
Default can't boost beyond 12 lbs.
ok i can't boost past 12 lbs for some reason it starts backfiring and stuff , i have a boost cut of 17lbs. on the hondata but it doesn't fell like a boost cut on 12 lbs. i just recently encounterd this problem
Old Oct 18, 2005 | 10:25 AM
Importordomestic's Avatar
Default Re: can't boost beyond 12 lbs. (vu337)
your blowing out the flame on your spark plugs, try a smaller gap.
Old Oct 18, 2005 | 10:26 AM
Default Re: can't boost beyond 12 lbs. (Importordomestic)
either that or you are detonating, take timing out
Old Oct 18, 2005 | 11:32 AM
null.'s Avatar
do you have a 3 bar map sensor?
Old Oct 18, 2005 | 11:54 AM
LSTEG96's Avatar
Default Re: can't boost beyond 12 lbs. (eg6junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6junkie &raquo;</TD></TR><TR><TD CLASS="quote">do you have a 3 bar map sensor?</TD></TR></TABLE>
im thinking no.
Old Oct 18, 2005 | 12:21 PM
I Have an STD's Avatar
wrenchin'
Default Re: can't boost beyond 12 lbs. (LSTEG96)
your stock map sensor is limited to 11.8 psi. so u cant do anything over that. i need either a motorola 2.5 bar map or a gm 3 bar
Brett
Old Oct 18, 2005 | 03:59 PM
D@nnY's Avatar
Default Re: can't boost beyond 12 lbs. (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">your stock map sensor is limited to 11.8 psi.
Old Oct 18, 2005 | 06:22 PM
vu337's Avatar
i do have a 3 bar map sensor i got it from camp1320, i just started doing that, never did it before, should i change my spark plugs back i have the ngk R5671a, do i have to change it back cause of the weather or what, i check the plugs today and it look ok but didn't check the gap, i have it gap at 28 that's what tony1 told me to do, and i check the cap and rotor , it has a little white residue the cap i new, wires are new and cap not that old please help cause it is pissing me off, how do i lower the timing, it is already tune for 15lbs of boost by tony1
Old Oct 18, 2005 | 06:25 PM
vu337's Avatar
bump! if someone can help me my aim screen name is vu318 thanks
Old Oct 24, 2005 | 04:50 PM
vu337's Avatar
thanks guys for the help i found out what the problem was the spark plugs, when i check them i forgot to check the gap which was 42 so i brought some new ones and gap them at 28 thanks
SilverPanda
Oct 9, 2007 01:16 AM
Topdawgg
Jan 18, 2006 05:15 PM
BoostedJeff
Sep 24, 2004 09:27 AM
Beer
Jun 19, 2002 11:44 PM
Pro-Lude
Aug 29, 2001 04:26 AM
