can it be re-used or replace?
Old Jun 10, 2013 | 04:19 PM
shocker911's Avatar
Default can it be re-used or replace?
as the title says would you re-use this JE piston? i got a hell of a deal for 4 eagle rods and 4 JE pistons (120 bucks) just looking them over saw this. for 120 bucks im not bitching.
if i re-place do i just contact JE??
its going to be in a 600+ H2B turbo drag car
Old Jun 10, 2013 | 04:39 PM
th3pwn3r's Avatar
Default Re: can it be re-used or replace?
I wouldn't use that. How do the rods look?
Old Jun 10, 2013 | 04:58 PM
shocker911's Avatar
rods all look good no knicks in them at all. I have no idea how the piston got beat up without any rod damage
Old Jun 10, 2013 | 06:13 PM
turbohatch96y7's Avatar
How do the skirts look? If the skirts are fine get them rebalanced and run em.
Nothing contacts the bottoms of the pistons.
Shave down really sharp edges, balance, reuse.
Old Jun 10, 2013 | 06:22 PM
Gunmetal_B20_Hatch's Avatar
It should be OK. As long as the skirts and domes are OK you shouldnt have a problem. Make sure the pin rotates OK also.
Old Jun 10, 2013 | 06:27 PM
wantboost's Avatar
Who is Mr Robot?
As long as there's no damage to the underside of the piston top and that the pin bosses haven't bent or warped you should be okay. Put a pin in it and check that it rotates and moves smoothly, also put a rod on the piston and see if the piston is straight inline with the rod
If all is good simply and carefully file/grind/polish the damage away as best as possible and you should be fine
Hell my 2 of my pistons have material transfer damage on the pin side of the piston and the machine shop said they were fine to use.
Old Jun 10, 2013 | 08:24 PM
SPOOLINmatt's Avatar
what the hell did they do? Smoke a bowl from the pin side of the slug???
Lil Tones
Feb 11, 2011 02:45 PM
SiR99
Sep 1, 2006 09:17 PM
jakscivic
Jan 13, 2006 02:48 PM
forcedaccord95
Apr 30, 2005 10:07 PM
Honda Sport
Jan 14, 2004 08:19 AM
