Can a Leaky/bad turbo cause a blown motor?
As the topic says, im just curious if a leaky or bad turbo could cause a motor to blow. If it can what exactly causes the motor to blow?
Re: Can a Leaky/bad turbo cause a blown motor? (ShapeGSX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShapeGSX »</TD></TR><TR><TD CLASS="quote">Sure it can. Oil is very low octane. If it leaks oil into the intake, it can lead to knock.</TD></TR></TABLE>
This is what took my first motor... The oil was leaking into the charge pipes and made its way into the #4 runner primarly. Just driving down the road one morning the check engine light went off and when I checked it later, it was a random misfire code on #4. Turns out the ring land cracked under no boost at all. This is what really turned me off to turbos.
starcrossed010
02-22-2007 03:37 PM
turbo95eg6
11
03-10-2005 07:43 PM
