Can I run non intercooled? (quick answer!)
Old Sep 27, 2002 | 07:05 PM
legendboy's Avatar
Default Can I run non intercooled? (quick answer!)
I can not get my intercooler tigged until next week, can I run non intercooled?? ls turbo @ 7 psi 3 degrees of retard base timming? Need a quick answer, have car apart in shop continue with install or go stock untill intercooler done.
Old Sep 27, 2002 | 07:30 PM
rjardy's Avatar
Default Re: Can I run non intercooled? (legendboy)
yes
Old Sep 27, 2002 | 07:37 PM
PrecisionH23a's Avatar
dont run high boost without the intercooler, stay with around 4psi
Old Sep 27, 2002 | 07:43 PM
ninesecrx's Avatar
Default Re: Can I run non intercooled? (GudeH23a)
Just use methanol as gas and you will be fine.
Old Sep 27, 2002 | 08:54 PM
tony1's Avatar
Default Re: Can I run non intercooled? (ninesecrx)
Funny...don't try it!! Some of these guys don't know any better and might actually try it.
Old Sep 27, 2002 | 09:15 PM
SoulSurfer's Avatar
Default Re: Can I run non intercooled? (tony1)
It's true...I'm a moron. Ask Rob.
Old Sep 27, 2002 | 11:25 PM
madman604's Avatar
sure, just dont expect to run full boost. meaning DON'T FLOOR IT.
Old Sep 28, 2002 | 02:27 AM
ion_four's Avatar
Default Re: Can I run non intercooled? (Turbo E)
dood, you can run 7psi non-intercooled. as long as the ignition is backed off a bit and you have enough fuel it's all good, just not efficient. there are people that run alot more boost than that, non-intercooled (10+psi on hondas and I know of a guy that roadraces a dodge in a particular class where he can't add an intercooler, but can up the boost...he's running about 18psi!!!, which is crazy )
Old Oct 1, 2002 | 05:51 AM
craesq's Avatar
I ran a stock engine Integra LS at 7psi with no intercooler for a year with absolutely no problems. Fuel management was stock injectors with only a 12:1 Vortec FMU. I had the pedal to the floor and the engine to redline all the time. I have the piping if you want it (I just got an intercooler).
SOHC50shot
18
Mar 19, 2004 10:49 AM
SOHC_MShue
Mar 21, 2003 01:50 PM
civicmark
Jul 12, 2002 06:41 PM
Duck Sauce
Nov 26, 2001 02:43 PM
prjctCIVIC
Jun 26, 2001 03:29 PM
