Cams + Boost
Old Aug 4, 2008 | 10:06 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Cams + Boost
Along my daily reading/learning I keep coming to a question.
Say for example which can would be best for a B18C with an InlinePro mani feeding a GT30R. I ask mainly because my old setup died a horrible death and my PeakBoost mani is going back for repairs.
Now for a cam that's safe on stock valvetrain, the choices are limited at best.
ITR/CTR
S2S1s
Blox Type A
BC3+(I'm actually wondering if anyone's tried these out yet)
I've read that if you go bigger than an ITR/CTR with a log manifold you lose power, but is that true with a cam along the same lift/duration as an ITR/CTR?
And before I get corrected, I know all those cams are bigger than an ITR/CTR, there just in the same league (Stg. 1 cam)
Comments are as always welcome.
Old Aug 4, 2008 | 10:27 AM
sp00led's Avatar
Default Re: Cams + Boost (black_EM1)
Skunk2 Tuner1s seems to be the way to go these days. Should make a little more power then the CTR/ITRs.
Old Aug 4, 2008 | 11:02 AM
black_EM1's Avatar
Community Builder
Default Re: Cams + Boost (sp00led)
Are they stock valvetrain compatible?
I ran CTRs on my last setup, stock valvetrain, and it ran fine. I'm a big fan of the stock revlimiter, it keeps me from doing stupid stuff.
Old Aug 4, 2008 | 11:10 AM
sp00led's Avatar
Skunk2 recommends upgrading your valvetrain but it says on their website it isn't neccesary.
Old Aug 4, 2008 | 04:42 PM
black_EM1's Avatar
Community Builder
As always.
Old Aug 4, 2008 | 05:36 PM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2 Tuner1s seems to be the way to go these days. Should make a little more power then the CTR/ITRs. </TD></TR></TABLE>
what are these cams about? Type R cams provide a wee bit less mid range than GSR cams but makes quite a bit more on the top end. now even though type R cams provide a little less mid range, its not to the point where its not enough, its basically a good balance. how do these skunk2 cams compare?
Old Aug 4, 2008 | 07:21 PM
sp00led's Avatar
Default Re: Cams + Boost (Boostage)
https://honda-tech.com/zerothread?id=2315276
Old Aug 4, 2008 | 08:23 PM
blinx9900's Avatar
on a boosted motor there is no aftermarket cam that is safe to use on stock valvetraing, assuming by valvetrain you mean springs/retainers.
Old Aug 5, 2008 | 03:31 AM
black_EM1's Avatar
Community Builder
Default Re: Cams + Boost (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">on a boosted motor there is no aftermarket cam that is safe to use on stock valvetraing, assuming by valvetrain you mean springs/retainers.</TD></TR></TABLE>
How so?
Old Aug 5, 2008 | 03:43 AM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">
How so?</TD></TR></TABLE>
cause factory honda valve springs are the SUCK! unless you have type R springs which are good enough for type R cams but still cant handle an aftermarket cam, there just not stiff enough and they cant handle the higher lift of anftermarket cams which leads to coil bind etc...
if your going to upgrade your cams you must upgrade your valvesprings and retainers END OF STORY, you dont take a shower and put on dirty underware do you?
Old Aug 5, 2008 | 05:51 AM
morgan@synapse motorsport's Avatar
if your going to upgrade your cams you must upgrade your valvesprings and retainers END OF STORY, you dont take a shower and put on dirty underware do you?</TD></TR></TABLE>
i agree with this statement. no need to put so much stress on the stock valvetrain when there are affordable springs/retainers available.
Old Aug 5, 2008 | 05:58 AM
black_EM1's Avatar
Community Builder
Whoa guy, no need for the hostility. I'm just trying to find out information, that's all.
Old Aug 5, 2008 | 06:03 AM
jmm96gsr's Avatar
I don't think he's being hostile, he's just speaking the truth.
Old Aug 5, 2008 | 06:09 AM
black_EM1's Avatar
Community Builder
Default Re: Cams + Boost (jmm96gsr)
Indeed.
I'm really trying to get at the technical specs on why this is, as far as boosted applications go.
crazihobo
Oct 12, 2011 02:48 PM
bboychris
Aug 18, 2002 09:41 PM
JDMvtecDRAGSTA
Mar 17, 2002 08:18 PM
Nighthawk GS-R
Mar 7, 2002 09:22 PM
b18c-93
Feb 6, 2002 07:49 AM
