ctr cams question?
ctr cams question?
i was lookiing into purchasing some ctr cams for my b16a.
can i use my stock valvetrain or should i use a better one?
i was planning on using both intake and exhaust,
do i also need cam sprockets? or can i use my stock ones?
thanks
thanks
Re: ctr cams question? (sohcmydohc)
you might as well go with the ctr/itr setup, because the itr and ctr exhaust cam are the same thing. also u could go with 2000-2001 intake itr cam, because it is pretty close to the ctr intake camand is cheaper, you should use itr valvetrain, or aftermarket(springs and retainers).
thanks
thanks
Shawn
Re: ctr cams question? (shawnhayes)
with cam gears you will benifit went you do dyno tuning to get the best gains out of the cams! you should also consider itr intake outters all around and portflow inners and bump the rev line to 8800 to create the best power of the cams.
