B18B1 PROBLEM???????
Old Sep 6, 2007 | 04:54 PM
speed84's Avatar
Default B18B1 PROBLEM???????
ON the motor left side of head there is a plug, alittle bit bigger than a 50 cent piece, it's above the big coolant hose, LEAKING a little bit of oil , but car runs good enought 98,008 miles .motors shakey at high speed. What do iI need to do???????? please help!
Old Sep 6, 2007 | 04:58 PM
deeznuts6009's Avatar
Default Re: B18B1 PROBLEM??????? (speed84)
hmmmm.
cam seal/plug. go to ebay,,, type b18b1 cam seal/plug, get one you like itll be about 10-15 shipped. and you will get it maybe in 2 1/5 -4 days like i did. anywhere else you will have to order it and will take longer. its easy to replace and yes its kinda over due to give out. G/L
Old Sep 6, 2007 | 06:33 PM
94 IntegraLS's Avatar
Default Re: B18B1 PROBLEM??????? (deeznuts6009)
Yea... If it is the cam seal/plug its a simple fix... get a new cam seal/plug, take off your valve cover... loosen/remove the exhaust cam holder #6, remove the old cam seal/plug and then install the new one and use hondabond to ensure a good seal... you might wanna change the valve cover gasket too since the valve cover is off...
Modified by 94 IntegraLS at 7:43 PM 9/6/2007
leakysi
Mar 17, 2010 10:04 PM
worktech
Feb 8, 2006 01:04 PM
DC2NING
Jun 23, 2004 02:38 PM
blackdude
Mar 17, 2004 08:55 AM
Sivicfied
11
Apr 25, 2003 10:32 AM
