Is the BW S258 comparable to a
Old Mar 8, 2009 | 11:41 AM
BlakeJ53's Avatar
Default Is the BW S258 comparable to a
My turbo rebuild guy is supose to me making me a hybrid turbo. GT35R compressor housing and wheel, and a T3 82AR exhaust housing with a stage 5 turbine wheel. Well he is having trouble finding the 82ar housing cut for a stage five wheel, and I have a tunnig apaointment on saturday march 14th. Anyways..... He has offered me a BW S258 turbo with ETT, he say it has a 70ar exhaust housing but I think he meant 76 ar. Would the BW turbo be comparable the turbo I want built or not? I havent done a little resaerch on the BW but I really am not sure if the 2 compare.
Old Mar 8, 2009 | 01:07 PM
ScorpionT's Avatar
Default Re: Is the BW S258 comparable to a
Why not use a straight 35R? The stage 5 wheel doesnt flow as well 68mm UHP turbine. I can order the .82 housing for the Stage 5 wheel if you need, its not hard to get.
The S258 can be had in a .70 and .76 housings, but the .70 open housing is from Bullseye. Its a comparable turbo to a GT3076. The S362 is more similar to a GT35R.
Old Mar 8, 2009 | 01:23 PM
BlakeJ53's Avatar
[QUOTE=ScorpionT;37690925]Why not use a straight 35R? The stage 5 wheel doesnt flow as well 68mm UHP turbine. I can order the .82 housing for the Stage 5 wheel if you need, its not hard to get.
My rebiuld guy just has the compressor housing not the whole turbo. I also told him I wanted the 82ar housing with the stage 5 wheel. Because my tuner told me I needed a turbo bigger than my 60-1 t3 if I was going to use my skunk2 pro1 cams.
How much for the housing with 4 bolt discharge, and how much for the wheel?
Old Mar 8, 2009 | 01:57 PM
ScorpionT's Avatar
Does he have just the housing or the wheel also? Do you have the center cartridge also?
Edit: Are you going with a journal or ball bearing type?
Old Mar 8, 2009 | 02:24 PM
BlakeJ53's Avatar
He has the the compressor housing and compressor wheel.I am going with journal bearing. He has the center cartrige. We just need the 82ar turbine housing and the stage 5 turbine wheel.
Old Mar 8, 2009 | 03:04 PM
ScorpionT's Avatar
Ill check on the housing tomorrow, should be about $200 shipped. Im not sure on the turbine wheel, but I will find out.
I can get the same setup youre building for about $900 shipped, all assembled and balanced.
Old Mar 8, 2009 | 03:23 PM
BlakeJ53's Avatar
sweet lmk asap
Old Mar 8, 2009 | 06:54 PM
TheShodan's Avatar
Moderator
Depends upon your HP goal. (you never stated this), because the .70A/R can work just as well, for about 500whp or so. It's similar to a GT3076R through to a GT35R, when pushed far enough. It can work just fine depending upon your needs.
Old Mar 8, 2009 | 07:06 PM
BlakeJ53's Avatar
sorry..... 550 whp
Old Mar 8, 2009 | 07:42 PM
TheShodan's Avatar
Moderator
It can make 550, but it will need to be pushed over 30psi, in order to do it. Its very comparable to a GT3076R, GT3082, and GT3582 all in one.
Old Mar 9, 2009 | 09:05 AM
ScorpionT's Avatar
Blake, got the prices. Stage 5 wheel is $205 shipped, 4 bolt housing is $235 shipped. The 5 bolt housing is much more expensive, so I dont think you want that one.
BlakeJ53
Mar 8, 2009 02:28 PM
BlakeJ53
Mar 4, 2009 10:24 PM
jarvis199
May 15, 2007 11:55 AM
DeadVet
Jan 8, 2005 12:56 PM
