burnt valves or burnt rings?
Exhaust is making little popping sounds (misfiring) at idle. Idle is steady.
I held a piece of paper over the muffler tip and the paper is getting sucked into the muffler when it misfires.
Feels like its making the same power but burns a little more oil and gets a little worse gas mileage. Also vacuum is a couple inches lower than normal.
When I got the car built and tuned, I was told I would probably burn the stock valves in about a year from boosting. Well its almost been a year boosting 14 psi daily and this is happening. I wanted to build up the head anyways but I want to know how far to go with the head $ wise because I may need new pistons.
Do these symptoms sound like burned stock valves/valve seals or could it be that I melted a ring or piston?
Btw when I melted a piston before (my fault) the sparkplug was getting soaked in oil, idle was not steady and the plug was fouling out ever few days. Its very different this time.
Re: burnt valves or burnt rings? (RyanCivic2000)
trust me i havent been easy on them.
but on a side note, when the car warmed up today the misfire went away completely.
Anyone else's motor run better w/ hondata when motor is warmed up?
Re: burnt valves or burnt rings? (Turbo Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Chris »</TD></TR><TR><TD CLASS="quote">Anyone else's motor run better w/ hondata when motor is warmed up?</TD></TR></TABLE>
Yeah, mine.
I have RC 550cc injectors and Hondata. It makes a little bit of a popping noise and has an erratic idle until warm.
Yeah, mine.
mine was doing the same thing. when i took the engine apart , i found out that the pistons 3 chipped and all of them were melted. i really thought that it was just rings because the car still runs but it smokes when i let off the gas after getting on it. hope this helps....
stevil_knevil
11-17-2006 05:54 PM
