Spittng oil!!!
Spittng oil!!!
I've been having this problem with my 00 GSR, It spits oil though the exhaust and it idles like crap...........
DOes any one know what might be causing it???
Thanks guys
Thanks guys
Re: Spittng oil!!! (dwamp2006)
Yep, likely valve seals. Does it spit oil at load (cruising)? If not, then its probably the valve seals. If if gets worse with load, its probably the piston rings.
The idle could be a number of things... I know my brother had an idle on his and it was because the screws on his tb were a bit loose. But like a said... idle could be a number of things
drumminforev
09-11-2006 02:16 PM
jdm169
03-02-2003 06:11 PM
