Bulkhead fitting for oil return?
Old Sep 13, 2002 | 06:11 AM
jthelman's Avatar
Default Bulkhead fitting for oil return?
For my turbo oil return into the oil pan, I plan to use a fitting meant for a fuel cell.
It's AN-10, looks like a bulkhead fitting with a couple of nylon washers to seal the connection.
This seems like it's too easy - drill hole, slip in the connector, and tighten. No JB Weld or regular weld.
Am I missing something?
John
[Modified by jthelman, 3:12 PM 9/13/2002]
Old Sep 13, 2002 | 07:18 AM
SiR Kid's Avatar
New User
Default Re: Bulkhead fitting for oil return? (jthelman)
Not missing anything. That's EXACTLY what I used.. I beleive it takes a 3/4" drill bit, BTW
I've never had any kind of leak from it either.
Old Sep 13, 2002 | 09:04 AM
93LSivic's Avatar
I just used a -10AN union, an oring, and a -10an bulkhead nut. No need for a bulkhead.
Actually I have this whold setup brand new if your interested. I live in Delaware county.
[Modified by 93LSivic, 1:06 PM 9/13/2002]
Old Sep 13, 2002 | 09:55 AM
Scott - 93HB Si's Avatar
Default Re: Bulkhead fitting for oil return? (93LSivic)
Pics? You just drilled into the opening in the middle of the turbo housing for the oil return? So I don't need to make a flange?
jprelude92
Aug 30, 2008 07:12 AM
shamoo
Oct 29, 2002 11:08 AM
pelotudo
Aug 18, 2002 10:15 PM
ion_four
Aug 2, 2002 02:30 PM
RATEDR
Jul 1, 2002 09:00 PM
