Looking for a good single layer head gasket
Old Jan 8, 2003 | 12:44 PM
zCivic's Avatar
Default Looking for a good single layer head gasket
This is for a B-series LS/Vtec so needs to be for a LS. What is yalls opinions on what to use..TIA
Old Jan 8, 2003 | 02:45 PM
MikeSarr_GSR's Avatar
Default Re: Looking for a good single layer head gasket (zCivic)
my opinion, ok
if you like your motor, raise compression with pistons use a stock or two layer head gasket and ARP head studs
Old Jan 8, 2003 | 06:49 PM
zCivic's Avatar
Default Re: Looking for a good single layer head gasket (MikeSarr_GSR)
Ok Well I have the P73 AO pistons (US ITR's). There going in a LS/Vtec with a B16 head. With the LS rods and I was wanting to run around 11.0/1 C/R. Well I can get that I just noticed with a 2 layer head gasket. That would be perfect. Now how do I go abouts this route? Where can I get a 2 layer? Or do I just get the OEM and only use 2 of the 3 layers? ARP head studs are in the works when the $$$$ is available. I currently have the pistons, rods are ready to be shot peened, block needs rehone, head is on lay away, have the GS-R crank girdle etc. Its a slow build up, trying to get done this summer. So yeah I kinda like the motor, or at least I should Wish me luck..
Old Jan 11, 2003 | 02:57 AM
mugen is a .47mm gasket and a 2 layer, $129 from inlinefour.com
Old Jan 13, 2003 | 03:41 AM
zCivic's Avatar
Yeah but its only for the V-tecs. Wont work with the LS/Vtec, b/c I need the LS head gasket. Dont want to modify it more then it already is going to be.
Tong.Y
Jun 5, 2011 09:17 PM
scooterbuilteh2
May 20, 2010 01:38 PM
grant97teg
Aug 25, 2009 11:31 AM
Jtuned DC2
20
Oct 1, 2007 06:05 PM
NOkTURNAL07.jp
12
Jul 2, 2006 10:22 AM
