build my bottom end?
Old Nov 1, 2001 | 06:45 AM
B17aTrbo's Avatar
New User
Default build my bottom end?
groupbuy seems to have everything im looking for...im getting the injectors (440s) soon but they also have eagle connecting rods ($349 set of 4) and JE/SRP pistons (JE $475, SRP $379)...are these good prices? i want to know what i should expect from going with this set-up and if it's even worth it??? right now i have the in-line pro headgasket but if i am gonna do it im gonna get the 9.0:1 compression pistons and put a factory headgasket in place...i wasn't really gonna do this now but if the prices are good i will take advantage of it if it's worth the $$$$$...next thing you know they'll have hondata on there and i'll be straight up fuct later.
Corey
Drag gen 2 turbo system, V-AFC, clutchmaster stage IV, adjustable cam gears, 3" test pipe, thermal R&D 3" turbo exhaust, turbo XS boost controller, LS transmission, 7psi, HKS external wastegate, more to come...
Old Nov 1, 2001 | 08:47 AM
B17aTrbo's Avatar
New User
Default Re: build my bottom end? (dc2jdmhonda)
naa when i get 440s i'll run 10psi or so...but i wanna make sure i can supply the fuel first, 7 is just me being conservative right now...when i go to the track on friday im gonna run some race gas and 9psi...after i get the injectors i'll ask the board what kind of boost i can run with my set up...right now im just putting the car together and then i'll tune and set max boost, and yeah i am running the vortech FMU that was supplied with the kit...later.
Corey
[Modified by B17aTURBO, 5:48 PM 11/1/2001]
Old Nov 1, 2001 | 10:26 AM
DLB1994's Avatar
Default Re: build my bottom end? (B17aTURBO)
with the 440cc u need a 5:1 fmu disk thats what i got and used the afc to tune them down at low rpms
Old Nov 1, 2001 | 10:28 AM
DLB1994's Avatar
u have a in-line pro headgasket right now and u only runing 7psi
Old Nov 1, 2001 | 03:56 PM
AshlandSi's Avatar
Default Re: build my bottom end? (DLB1994)
Hey B17a, I have a B17 as well and Eagle doesn't make "off-the-shelf" rods for it....unless the sources I have are wrong.
You'll have to go custom.
Old Nov 1, 2001 | 08:49 PM
B17aTrbo's Avatar
New User
yeah i only run 7psi because im sure the stock injectors are near their limit...i asked but no one could really tell me what kind of boost i could get away with...later.
Corey
Old Nov 1, 2001 | 11:50 PM
DLB1994's Avatar
what kind miles are on your motor
Old Nov 3, 2001 | 04:12 AM
B17aTrbo's Avatar
New User
89k miles on the motor in the car and 95k on the spare...
Old Nov 3, 2001 | 11:29 AM
DLB1994's Avatar
just get some injectors and boost up and later get some rods and pistons
Old Nov 3, 2001 | 11:34 AM
B17aTrbo's Avatar
New User
we are going to hook up zex nitrous kit @ 75 shot and turn the boost to about 12psi (or more) and see how many runs i can get out of this motor...
[Modified by B17aTURBO, 8:34 PM 11/3/2001]
Old Nov 3, 2001 | 12:09 PM
AbaZ's Avatar
Your stock rods should handle 300hp no problem with good tuning. Endyn doesnt make H beam rods for the B17 yet, but I bet if you call up T.O.O he could tell you a long story about when he will be making them.
Also a note, You will need to get your bottom end balacned after you installed Steel rods and Forged pistons since they are all differnt weights from your O.E Cast Pistons/Rods.
450cc injectors on a stock Prom? No way Not even with a FMU, you will get 14mpg, foul plugs and run very rich 0~8 psi. Trust me you will hate it!, I ran 380cc injectors with a FMU and I couldnt handle it. FP was even turned down to 20psi at idle just to keep my eyes from burning. The only way you are going to run a large set of injectors and daily drive this is with the Hondata system. Or Zdyne if you have a 88-91 CRX/Civic
Jeff
http://www.homemadeTurbo.com
Old Nov 3, 2001 | 12:14 PM
DLB1994's Avatar
Default Re: build my bottom end? (AbaZ)
thats what the s-afc is for tune them down
Old Nov 3, 2001 | 03:57 PM
ekb18c's Avatar
If i were you i would go some stand alone fuel management system. You should look into Accel DFI, or Haltech. You might as well do it once and then forget about it.
TEAM JDM-P
Oct 26, 2009 03:52 PM
lsvtecSIrex
Sep 4, 2006 07:21 PM
BOOSTED-EG
Jun 17, 2004 05:33 PM
swpdb16
Oct 23, 2002 10:06 PM
Beast53568
Aug 10, 2002 11:00 PM
