How to bleed water system ?
Old Feb 18, 2003 | 04:39 AM
mz3bo's Avatar
Default How to bleed water system ?
Hi, how can I bleed my coolant system on my b18b in a 1992Hb. The water temp is going up and down like a coaster.
Thanks
Old Feb 18, 2003 | 05:59 AM
altoid's Avatar
Default Re: How to bleed water system ? (mz3bo)
petcock on bottom corner of radiator
Old Feb 18, 2003 | 07:08 AM
ForeignConcepts's Avatar
usually improper coolant levels will cause the engine to idle up and down. so check coolant level. but for the 15-20 fix, change the thermostat. and gasket if that does the trick good, but if it comes back id say you may want to look at a new head gasket cause coolant leaking elsewhere...
Old Feb 18, 2003 | 12:37 PM
Perfectionist's Avatar
To answer your question... If you follow the upper radiator hose to the engine you will see a 10mm bolt around a stud with a small hole in it. You loosen this to bleed the air from the system until the coolant flows steadily. Don't forget to replenish the coolant in the overflow recovery bottle.
Old Feb 18, 2003 | 02:02 PM
ill phil's Avatar
Default Re: How to bleed water system ? (Perfectionist)
I had air in my coolant after replacing the radiator and as a lazy fix to stop a surging idle I just turn on the car and let it warm up with the radiator cap off. This let bubbles come to the surface and fixed my surging idle.
4doorpowa
Jan 24, 2011 12:50 PM
SeanK325
Jun 22, 2010 02:52 PM
Tunerguy1989
Jun 15, 2010 12:16 PM
bgtcket5
Aug 5, 2007 05:15 AM
drumsy
Sep 12, 2002 07:14 AM
