Broke Piston Ring Lands?
Old Jun 1, 2003 | 03:35 PM
flat-blk-HB's Avatar
Default Broke Piston Ring Lands?
What would this be like? I think this is might have been what happend to my car last night. There is a lot of oil...EVERYWHERE..under the hood puddling every where..And when you pull out the spark plug wires there is Oil about 2" deep in 2 of them..And then when you pull the plugs on the others they are dripping with oil...The car ran and yes it sucks to have to drive it but I got it home..1.5 hours from the track..SMOKING LIKE NO OTHER.....It sucked *****....
Ohh yeah I did run 2 13.8's with my HM kit on my D16Y8....Steet tire...Shitty 60 footers too like 2.3-2.4....This was at about 8-10 psi...Spiking too 10 then going down to 8...SHitty MBC...The ran it messed up on it spiked to 15.... ...My fuel upgrades are only 12:1 FMU and inline pump
Old Jun 1, 2003 | 04:35 PM
Default Re: Broke Piston Ring Lands? (flat-blk-HB)
Nobody knows?
Old Jun 1, 2003 | 07:32 PM
Come on somebody knows something....
Old Jun 1, 2003 | 07:41 PM
00SIBOOST's Avatar
Do a compression test. Then take apart the engine and see exatcly what you did. Either threw a rod, cracked ringlands etc. who knows until you rip it apart
Old Jun 1, 2003 | 07:52 PM
earl's Avatar
Default Re: Broke Piston Ring Lands? (00SIBOOST)
Could be just about anything. Not enough info to even guess. Broken ring land will bellow smoke out the exhaust but you probably would have used all your oil up driving home.
Old Jun 1, 2003 | 08:43 PM
b16ahybrid's Avatar
good runs, get your 60' times down a little and your in business.
Oh yeah and your engine...uh do a leakdown/compression test. If you have oil like that you have serious problems. time for a new motor
Old Jun 1, 2003 | 09:53 PM
MiraiZ's Avatar
could also be seriously cracked or melted pistons...does the engine run at all???
Old Jun 1, 2003 | 10:30 PM
lazerus's Avatar
Default Re: Broke Piston Ring Lands? (MiraiZ)
engine is done, pistons trashed, time to start over.
onesick97ek
Sep 30, 2012 03:21 PM
jdmadam
24
Apr 18, 2012 10:49 AM
1badcrx
Jan 29, 2012 09:40 PM
f1 vtec
Feb 25, 2006 01:04 PM
ss20gsr
Nov 25, 2003 03:21 PM
