spark plug- reading?
Old Feb 23, 2006 | 11:16 AM
f1 vtec's Avatar
Default spark plug- reading?
Hi,
Im not too clear on how to read spark plugs any help would be appreciated. My motor is a b18c with 9.01 comp, the comp is as follows 180 180 150 180 i pulled the plugs and the plugs were as follows-
180 cyl's- Black rim and the tip was a whitish colour
150 cyl- was all black with this sooty residuue thing not very much of it.
now what can i gain from reading these plugs and what do they mean?
Old Feb 23, 2006 | 11:25 AM
nsxxtreme's Avatar
Default Re: spark plug- reading? (f1 vtec)
The black is your burning oil or really rich.
The 150 psi suggest your rings are bad.
try adding a small amount of oil to this cylinder. Then retake your compression test if the psi goes up then your rings are bad.
I would suggest doing a leak down test it will tell you more the a compression test.
Old Feb 23, 2006 | 11:37 AM
f1 vtec's Avatar
Default Re: spark plug- reading? (nsxxtreme)
Its what i was thinking too put i dont see any oil diisappearing also the compression 180 is pretty good for a 9.01? ive just recently had the pistons installed.
will adding oil to the cylinder damage it oor cause an excess build up of carbon or something.
Old Feb 24, 2006 | 04:36 PM
LSVTEC 91 Civic's Avatar
Banned
Plug electrodes should look tan. Also, make sure you are using a plug with the proper heat range.
I call a bad valve seal on that low cylinder, if the plug is oil fouled.
Old Feb 25, 2006 | 04:03 AM
f1 vtec's Avatar
Default Re: spark plug- reading? (LSVT3K 91 C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C &raquo;</TD></TR><TR><TD CLASS="quote">Plug electrodes should look tan. Also, make sure you are using a plug with the proper heat range.
I call a bad valve seal on that low cylinder, if the plug is oil fouled.</TD></TR></TABLE>
i still havent corrected mmy clearnaces could that be an issue
Old Feb 25, 2006 | 12:20 PM
nsxxtreme's Avatar
Thats why I meantioned to do a leak down test it will tell you where your leaking
Old Feb 25, 2006 | 01:04 PM
civic_gsr_transplant's Avatar
i agree with nsx on the leak down test especially because you can have a bad compression ring,but your oil rings might be good indicacting oil comming from else where(like valveseals)
jtrig
Honda Civic (2001 - 2005)
Jun 2, 2015 03:55 PM
follie gatts
Jun 4, 2011 10:34 AM
.:urbandc2:.
15
Dec 8, 2008 12:28 PM
DriveSideWays
Aug 22, 2004 07:19 AM
GSR4door1
Mar 31, 2004 06:39 PM
