HELP IM GONNA BLOW MY MOTOR!!!!
Old 11-24-2003, 11:13 AM
ss20gsr's Avatar
Default HELP IM GONNA BLOW MY MOTOR!!!!
well ive had the drag three kit on my car since april and i didnt have the fuel pump installed since june (but i never boosted knowing that it would run lean) the kit was preforming really nice and now the exhaust is starting to smoke so i checked under the hood and the breather is smokin as well. my guess is the rings are goin out, i thought it was the head gasket but its not leakin out the bottom, i really dont know how this happened and so fast
any suggestions or comments
P.S. its my weekend car so the kit only has 3500 miles, but the car itself has 52000 miles!!!!
Old 11-24-2003, 11:16 AM
Ri5e's Avatar
Default Re: HELP IM GONNA BLOW MY MOTOR!!!! (ss20gsr)
Rings must be fine, ring lands are probably gone! Do a compression test
Old 11-24-2003, 11:30 AM
maxim's Avatar
Default Re: HELP IM GONNA BLOW MY MOTOR!!!! (Turbo God)
I have the same kind of question. My car smokes sometimes when I am sitting in traffic for a while. It is not consistent though. I did a compression test on my car a week ago and everything was perfect: 220 200 220 225. Spark plugs were brown(good), so I wasn't detonating during that time. I looked down into the spark plug holes and noticed my pistons were pretty black and wet. The car still smokes a bit in stop and go, so maybe a compression test is not a clear indicator of what is happening. Maybe a leak down test would be better.
Old 11-24-2003, 07:50 PM
ss20gsr's Avatar
Default Re: HELP IM GONNA BLOW MY MOTOR!!!! (maxim)
any one else?
Old 11-24-2003, 07:52 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo God &raquo;</TD></TR><TR><TD CLASS="quote">Rings must be fine, ring lands are probably gone! Do a compression test </TD></TR></TABLE>
Id suggest this, then go from there
Old 11-24-2003, 07:55 PM
Cramerox's Avatar
he said it. get a comp test. get a fuel pump and get a better fuel management if you are running a FMU.
Old 11-24-2003, 08:22 PM
E-thug
boostismycrack's Avatar
my gsr does the same, I think its a bad valve stem seal. I'm going to yank the head soon to see what's up.
Old 11-24-2003, 09:04 PM
SOUNDEFFECTS's Avatar
Default Re: HELP IM GONNA BLOW MY MOTOR!!!! (boostismycrack)
Maxim, I would guess its your turbo. If its got good compression and smokes only out of the exhaust off and on then its the turbo. I have a motot with messed up oil control rings and it still had good numbers
Old 11-25-2003, 01:17 PM
maxim's Avatar
Default Re: HELP IM GONNA BLOW MY MOTOR!!!! (SOUNDEFFECTS)
Thanks Soundeffects, that's good to hear. At least it's not the engine.
Old 11-25-2003, 03:21 PM
ss20gsr's Avatar
thanks for all the replys, im gettin the compression test later this week and ill see whats up
jdmadam
24
04-18-2012 10:49 AM
wacktical
10-04-2005 01:18 PM
flat-blk-HB
06-01-2003 10:30 PM
fongyuen
12-07-2001 04:34 PM
Quick Reply: HELP IM GONNA BLOW MY MOTOR!!!!
