break in!!!??
Old Jun 2, 2011 | 06:39 PM
  #26
bowtieboy911's Avatar
Default Re: break in!!!??
so priming it is just basically turning it over to get the oil to the head??
Old Jun 2, 2011 | 06:57 PM
  #27
MR.johnson's Avatar
and every other oil passage/galley.
Old Jun 2, 2011 | 07:00 PM
  #28
so i should keep valve cover off to make sure oil is getting circulated? before i start it up
Old Jun 2, 2011 | 07:11 PM
  #29
rich7777's Avatar
NO, its to supply oil to the whole engine so when you turn the key you already have oil where its needed.
Old Jun 2, 2011 | 07:20 PM
  #30
ok so how exactly do you prime it do you turn key on to acc or on and leave it there for 30 seconds the click it back or do you actually turn it over for 30 seconds??
Old Jun 2, 2011 | 07:27 PM
  #31
th3pwn3r's Avatar
Please take your car to a shop and have someone do it for you.
Old Jun 2, 2011 | 07:28 PM
  #32
rich7777's Avatar
I remove the plugs, disconnect the distributor plug and crank the car over until the oil light goes off.
Old Jun 3, 2011 | 04:45 AM
  #33
BigMike0147's Avatar
+1 to that. I'm going to do it until I read oil pressure on my gauge I installed. It's a great thing to have to make sure you're in spec with pressure too.
Old Jun 3, 2011 | 07:28 AM
  #34
pcguy760's Avatar
Originally Posted by MR.johnson
lol. rod knock has nothing to do with the way you broke it in.
talk to your engine builder...
EDIT: why give the wrong info on breaking a motor in when you never even checked clearances??????!!!
https://honda-tech.com/forums/forced-induction-16/experiencing-slight-rod-knock-%40-idle-help-2942864/
thanks for all your help.
Clearances??? Whats that suppose to be??? LOL - I am glad I TRIPLE checked all my clearances
Old Jun 3, 2011 | 07:32 AM
  #35
pcguy760's Avatar
Are you serious?? The guy built the engine by himself and then he is gonna take it to a shop to have them prime it lololol....
You're not serious right....are you? lol.
Old Jun 3, 2011 | 07:38 AM
  #36
i had a shop build it and im not taking it to a shop??
Old Jun 3, 2011 | 07:57 AM
  #37
welfarepc's Avatar
i just use bosch filters. they are great.
PatrickGSR94
Aug 31, 2017 10:04 AM
slow_low_eddie
Jan 9, 2014 05:37 PM
bowtieboy911
Engine Management and Tuning
Jun 4, 2011 04:56 AM
pcguy760
May 25, 2011 06:23 PM
MayhemSi
Jan 19, 2003 08:33 AM
