BOV opening under boost
I have a Tial BOV and when I boost anything over 20 psi it starts fluttering and opening and closing under boost, causing my boost to climb and drop from 30-20 psi. Under 20 psi it works fine. Anyone else have this problem? I'm thinking it might just have a bad vacuum source, but thought I would post before I changed it. It is teed into my FPR line. I thought it might be the spring, so I tried my buddies BOV and it did the same thing. His car is on 24 psi with no problems.
I did search and found a couple people with a similar problem, but never any answers!
No kidding. You can get a cheap vac block for all of $20 with every sort of fitting. I've seen COUNTLESS stemming from teeing off tiny lines such as the FPR - especially when it feeds everything else. Its the only time you'll see the datalog show the MAP at a steady RPM, while the boost gauge vibrates from 0-15psi a hundred times per second.
More often than not, removing all tee'ing from your system by using a vac block solves this issue. If it was a steady leak I'd say no, but if it bounces around, its very likely.
Tried giving it a vac source of its own and still the same thing. I even unplugged it from vacuum and the car still does the same thing. I tried a different boost controller to see if it was causing my wastegate to flutter, but still the same. After talking with Tial and reading about compressor surge, I think that is what I'm experiencing.
ok I have been searching and going through every single post I could about compressor surge, but almost all of them are talking about the sound the bov makes when they let off the throttle. Mine sounds like the bov opening but I'm still in WOT. I'm guessing this is true compressor surge when it does this. My question is what exactly causes this? The turbo is out of it's efficiency range, but is it because it flows more then the motor can handle or can't flow enough?
To maybe help my setup is a vitara built d16z6 with a stock head and intake manifold. Mini ram exhaust manifold, Garrett t3/t4 60 trim, .63 exhaust, 3 inch dp, Tial 38mm wastegate-15 psi spring, 50mm Tial BOV, 2.5 inch intercooler piping, ebay 29x12x3 intercooler, precision 1000cc injectors.
http://www.turbobygarrett.com/turbob...o_tech103.html
There are tons of people running turbos larger then mine on d16z6's without surge. One thing I have noticed is it doesn't do it in 2nd gear, but there is less load because it just spins and rpm's climb a lot faster.
EJ1 wilcox
Feb 3, 2007 10:32 PM
Nextelbuddy
Jun 12, 2004 06:39 PM
