bov open at idle(tial) normal???
Old Oct 22, 2006 | 04:49 PM
eg:R's Avatar
Default bov open at idle(tial) normal???
Modified by eg:R at 6:52 PM 1/31/2007
Old Oct 22, 2006 | 06:50 PM
StylishDOHC's Avatar
Default Re: bov open at idle(tial) normal??? (eg:R)
yeah it's fine.my stock dsm does it too.
Old Oct 23, 2006 | 09:05 AM
eg:R's Avatar
ok thank, someone told me that the bov suppose to be close at idle that why i wanted to make sure.
Old Oct 23, 2006 | 09:14 AM
atec's Avatar
I`ll answer in a way I hate...
Yes and No!
Old Jan 31, 2007 | 09:56 AM
eg:R's Avatar
Default Re: bov open at idle(tial) normal??? (atec)
my tial bov stay open at idle. went to a local shop and they have said that all bov suppost to be close.. every one here have been telling me yes and no, so im not to sure my self.
Old Jan 31, 2007 | 11:03 AM
a1320addict's Avatar
what spring is in it? my tial is slightly open at idle.
Old Jan 31, 2007 | 11:41 AM
morgan@synapse motorsport's Avatar
Default Re: bov open at idle(tial) normal??? (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">what spring is in it? my tial is slightly open at idle.</TD></TR></TABLE>
i can see my ring that seals my tial at idle, id imagine once the engine sees boost it pushes down because of the boost line connected at the top.
Old Jan 31, 2007 | 11:46 AM
SOHC_MShue's Avatar
at atmospheric pressure it will be full closed and opens under vacuum. How much it opens probably is determined by which spring you have. The 7psi spring will probably open more than the 11psi spring at idle.
Old Jan 31, 2007 | 01:12 PM
StolenTeg's Avatar
Default Re: bov open at idle(tial) normal??? (SOHC_MShue)
The bov should be open but not fully open, BOV open to vacuum and when your engine is idling it is in about 22 inhg so it should be open
Old Jan 31, 2007 | 01:27 PM
eg:R's Avatar
i got a 7lb spring. just got a message from tial and they said the bov should be slightly open on idle. ordering me a 12lb spring. i have a 23in vacumm at idle.
Jupe
Jul 8, 2007 02:42 PM
vladd
Jan 11, 2007 11:06 AM
Steve91
Nov 23, 2005 09:22 AM
NotUrAvgSi
Sep 14, 2004 10:37 AM
_Endless_
Jul 4, 2003 10:56 AM
