Need information ASAP
Old Jan 30, 2007 | 11:50 AM
boostedek9's Avatar
Default Need information ASAP
Ok, so I heard about a method of relieving positive bottom end pressure on honda motors. The person told me that by removing the two bungs on the back of the block and drilling and tapping them to accept an AN fitting, you can use a catch can to relieve the pressure, sorta like pulling your pcv valve but no leaking. I dont know if this is a good idea or not and I was looking for some more information on it, but has anyone heard of this? Is it a good idea like putting bungs on the valve cover for a catch can? Thanks guys
Modified by boostedek9 at 4:02 PM 1/30/2007
Old Jan 30, 2007 | 12:05 PM
ZeremiaH's Avatar
Default Re: Need information ASAP (boostedek9)
bump for more info!!
If this is true, I need to tell Joe while he is building my motor.....
Old Jan 30, 2007 | 12:45 PM
xenocron's Avatar
Default Re: Need information ASAP (ZeremiaH)
Search for a thread started by user 'DASHER' about PCV systems and breather setups
Old Jan 30, 2007 | 01:04 PM
boostedek9's Avatar
searched and read, I see he talks about breathers and what not, but not much about the bottom end and if this is a good idea or not?
Old Jan 30, 2007 | 01:22 PM
a1320addict's Avatar
Default Re: (boostedek9)
http://www.theoldone.com
If you are really against drilling the OEM fittings out and welding on, http://www.z10eng.com
#Z10-4006
Modified by a1320addict at 9:17 PM 1/30/2007
Old Jan 30, 2007 | 03:32 PM
TypeSLO's Avatar
Default Re: (a1320addict)
you don't need to do the AN fittings but if you fab it to make it work for the bling effect, make sure it's a lot larger than the -4 size you show in the pic.
Old Jan 30, 2007 | 04:53 PM
redboost10's Avatar
Default Re: (TypeSLO)
scott just got done welding -12 bung on my two block fittings. get some steel weld-on bungs, weld them on, then drill them out.
some will say its a good idea, some will say its the dumbest thing you can do
Old Jan 30, 2007 | 04:59 PM
2redstars's Avatar
http://www.theoldone.com/components/breather/
Old Jan 30, 2007 | 05:28 PM
advert's Avatar
i think the valve cover is a beter idea to weld them onto. reason being those are oil drains and the oil is just going to run into them... of the valve cover you get the same effect with out waisiting as much oil
thats imo some people like this way, i dont.
Old Jan 30, 2007 | 05:34 PM
boostedek9's Avatar
Is it necessary to do both? to relieve pressure in the bottom end and the top? or can one just be done and the problem be executed
Old Jan 30, 2007 | 05:38 PM
If you're having blow-by problems, off the back and the valvecover is the way to go
Old Jan 30, 2007 | 05:42 PM
advert's Avatar
no i think the top its self is fine.
you have oil ways up to the top so that extra air is going to make it up there to be relived.
Old Jan 30, 2007 | 10:09 PM
redboost10's Avatar
i also have two on the valve cover
Old Jan 31, 2007 | 01:39 PM
boostedek9's Avatar
True, well I guess I'm gonna try it out!
97civicswapped
Jan 5, 2014 01:39 PM
scspeed
Aug 4, 2008 01:58 AM
Royal_C!ty
May 8, 2005 10:27 AM
Billy_goat
Oct 4, 2003 02:44 PM
Stupid Ass
Jan 21, 2003 01:09 PM
