boosting stock b16a
Old Jun 17, 2003 | 05:20 AM
mattcalica's Avatar
Default boosting stock b16a
i am planning on boosting my b16a. I wanted to know how much boost the internals can handle. I will be using a toda head gasket which will lower the c/r to about 10:1, and i am going to use the vafc hack, with the 440 injectors.. I was planning on using a t3/t4 turbo, ic (of course). how much will i be able to boost, before having to go internal?
Old Jun 17, 2003 | 08:06 AM
drvfast's Avatar
Default Re: boosting stock b16a (mattcalica)
7-8 psi safley with good fuel managment and tuning
Old Jun 17, 2003 | 11:26 AM
b16ahybrid's Avatar
Default Re: boosting stock b16a (drvfast)
If you don't skimp on the fuel and spark you should be good for about 10psi with no problems
I'm runing .65 bar with no problems.
get a pump, those injectors, v-afc, and something to control you timing and you should be good
Old Jun 17, 2003 | 11:32 AM
TurboJesse
Guest
Posts: n/a
Default Re: boosting stock b16a (b16ahybrid)
10psi daily with good tuning (hondata, etc)
Old Jun 17, 2003 | 11:40 AM
hybridreams's Avatar
Default Re: boosting stock b16a (Mpir3)
A friend on this board has hit 1 bar in a bone stock B16 with DSM injectors and Zdyne. Not sure about the details. I'll see if he's willing to post...
Old Jun 17, 2003 | 04:14 PM
blackteg's Avatar
Hybridreams was talking about me. I have hit 1 bar several times on a compltely stock motor. I have actualy gone a little over 1 bar on a couple of occasions. I am not rcommending for you to do this but I personaly haven't had a problem with it. I am sure everyone else will say I am dumb for doing it, but so far so good. I am switching to Hondate when I find the time to install it and will be running 1 bar on that as well after its tuned. Good luck with what ever you do.
Old Jun 17, 2003 | 04:15 PM
blackteg's Avatar
Also, not sure you would want to even bother with the Toda head gasket considering that the stock compression is 10.2:1.
Old Jun 17, 2003 | 04:28 PM
TurboJesse
Guest
Posts: n/a
Default Re: boosting stock b16a (blackteg)
he might have a JDM b16a SIRII with 10:4:1 comp...either way i would still run 10psi daily...personally i have the same engine with inline pro 3mm headgasket and plan on running 12 daily and 1 bar at the track.
Old Jun 17, 2003 | 04:32 PM
blackteg's Avatar
Yea, good point, could be an SIRII. I can't recommend for him to do the same as me, he might not be as lucky as me.
Old Jun 17, 2003 | 06:27 PM
EVOLMTR's Avatar
I ran 9 psi with a bone stock jdm b16 gen 1. This was done with a shitty *** 12:1 fmu and stock 240cc injectors with some cold plugs. I had no problem.
9 psi wasn't fun eough for me so, i ditched it and now building a sleeved low compression block.
Old Jun 18, 2003 | 02:48 PM
RAWB's Avatar
I've been runnin my stock JDM B16, boosting between 6-10psi daily and occasionally, spiked to 1bar for about 2 1/2 years <<--- NOT RECOMMENDED!!
-8psi daily(and boost spike) for about 2 years on the 12:1 FMU and inline, stock injectors
-8 months pushing 6-10psi on the AFC hack.
I checked compression a couple months ago and still had about 190 across the board. Personnally, I would recommend no more than 10psi, daily. GL
Old Jun 18, 2003 | 05:08 PM
maxpsi's Avatar
I made 271HP/188TORQUE on 10psi of boost tuned by Hondata on 93 octane with my B16. I have ran it plenty of times with no problems. I still drop in some 110 leaded when I run 10psi though just to be on the safe side. Boost is relative. You should be asking how much power can a stock B16 handle. Well, so far you have plenty of example including my own. I hope this answers your question. Check my sig!
Old Jun 19, 2003 | 04:56 AM
Default Re: boosting stock b16a (maxpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi &raquo;</TD></TR><TR><TD CLASS="quote">Boost is relative. You should be asking how much power can a stock B16 handle.</TD></TR></TABLE>
He's actually asking the right question by wanting to know how much boost a stock B16 can handle on a t3/t4 turbo. If he didn't specify the turbo being used, then you'd be right.
Ryhaz
Jun 8, 2014 03:21 PM
Powelly
10
Jun 18, 2007 01:25 PM
skitzo7170
Nov 17, 2004 09:53 PM
Giuseppe
Sep 24, 2001 10:36 PM
