Boosting an LSVTEC?
Old May 3, 2003 | 07:11 PM
B16OnTop's Avatar
Default Boosting an LSVTEC?
Hey everyone i have a B18 block with a B16 head type r internals and a GSR ECU. I was just wondering how good it would be for my engine if i got it sleeved then turboed it the turbo kit would either be a drag kit or just a custom one but would it be safe to boost this engine? i am aware the compression is prob really high but even if it was sleeved and tuned properly how long do you think it would last on say 6-10 PSI for starters? just curious
Old May 3, 2003 | 07:20 PM
InfamousRS's Avatar
Default Re: Boosting an LSVTEC? (B16OnTop)
It wont be any less safe than boosting anyother engine if its properly built.
Just out of curiosity, what pistons are you going with?
FYI: B18b sleeves are no weaker than b18c sleeves.
Old May 3, 2003 | 07:22 PM
B16OnTop's Avatar
well right now i have ITR pistons in the future i'd prob get rid of them for something that can handle more boost but is that a good piston for boosting or not?
Old May 3, 2003 | 07:44 PM
Boost2NA's Avatar
Default Re: (B16OnTop)
It all depends on your set up. If you are gonna sleeve the block I would go with a set of forged pistons and new rods. If you wanna keep the ITR pistons I really wouldnt boost it that high. There is a local guy that turboed his type r and at 5 psi he put down like 250 something. My advice would be to sleeve it and get some different pistons in there.
Old May 3, 2003 | 07:45 PM
TeStUdO's Avatar
if you use the same pistons just get an inline pro or cometic headgasket to lower compression
Old May 3, 2003 | 07:53 PM
B16OnTop's Avatar
ok so i decided ill prob. just get all new pistons, rods, and a new gasket but on the other hand lets talk some fuel management.What size injectors do you think would be best for a turbo lsvtec? then what type of computer for the management ive heard alot about the SAFC but how much better is a hondata then a SAFC?
Old May 3, 2003 | 08:01 PM
Tinker219's Avatar
I think you had better stick with Hondata. 550cc injectors. better research ALOT before you jump into anything...
Old May 3, 2003 | 08:11 PM
B16OnTop's Avatar
yes i realize i still have some research to do and all but i am just trying to figure out all that i am gonna do first thats why i am on H-T to get some opinions
Old May 4, 2003 | 11:43 AM
quikB18B's Avatar
I say keep your motor setup, swap pistons, rods, sleeves if u can get some 550's hondata tune and ull be happy and safe. I myself have thought about doinf that combo but if i did i would for sure du elike 9.1 9.5 compression, and for sure get some good beefy rods. to me my setp
i eventually wanna do is ls block/b20 block with pistons/rods, type R head(so i can rev a little higher and have a good flowing head, gsr tranny+ presicion turbo inline pro mani, damn here i go spending $ again.
ahenscheid
Feb 3, 2012 11:09 PM
slammedobd1teg
Apr 16, 2009 05:38 AM
skotsephrenia
Apr 9, 2008 01:34 AM
CIVICSI12
Sep 12, 2006 06:48 PM
speedncivic
Jan 12, 2006 12:04 PM
