Boosting issues.
Old Oct 26, 2002 | 09:33 PM
legendboy's Avatar
Default Boosting issues.
I installed my turbo wednesday and just fixed my dp and crap today. the car pulls really hard at 10psi and runs great. I installed a btm last night and now I am noticing my boost is hitting 15 psi!! I am running the wastegate (deltagate) and btm off the brake booster and boost gauge and bov of the fpr. I am running an safc and new btm and 440 DSM's. I have a .50 trim T3 (brand new) , custom manifold (wastegate port mounted right on top of the "log" ) custom 2.5" charge pipes and no intercooler yet. 2.5" dp and bosch bov. Am I safe boosting to 15psi? somehow I doubt it so what should I do?
also, what setup should I have engine wise to run 15psi daily ?
EDIT: I am not throwing any codes when hitting 15psi!
[Modified by legendboy, 7:05 AM 10/27/2002]
Old Oct 26, 2002 | 10:14 PM
rjardy's Avatar
Default Re: Boosting issues. (legendboy)
I am guessing that you are getting boost spikes off of that delta gate. Is the motor stock?
Rob
Old Oct 26, 2002 | 10:45 PM
wzcb08's Avatar
What kind of spring does the deltagate have. I know I have one that is adjustable from 9 to 15psi.
Old Oct 27, 2002 | 05:04 AM
legendboy's Avatar
Default Re: Boosting issues. (wzcb08)
My motor is stock, fresh rebuild. I have the 9-12 lb spring in my deltagate.
Old Oct 27, 2002 | 05:42 AM
rjardy's Avatar
Delta gates are adjustble if i am correct, so try turning it down.
Rob
Old Oct 27, 2002 | 06:18 AM
Fatty_1775's Avatar
Default Re: Boosting issues. (rjardy)
How can you tell what kind of spring you have in the deltagate and how do you adjust it? I am hearing two things, tighten it and you have more boost and also, tighten it and you have less boost!!! Which is true
Old Oct 27, 2002 | 06:24 AM
legendboy's Avatar
Default Re: Boosting issues. (import_racer)
take the spring out and look what color it is. the black spring is 9-12 and the green is 3-6 or something like that. tighting will increase boost.
Old Oct 27, 2002 | 09:45 AM
legendboy's Avatar
Fixed problem
Old Oct 27, 2002 | 10:16 AM
Colton Grundy's Avatar
how did you fix it?
Old Oct 27, 2002 | 11:14 PM
_Endless_'s Avatar
Default Re: Boosting issues. (derrickcxhatch)
yeah how did you fix it? what was the cause?
Old Oct 27, 2002 | 11:24 PM
easy jesus_151's Avatar
Default Re: Boosting issues. (_Endless_)
Inquiring minds want to know.
Old Oct 28, 2002 | 02:23 AM
rjardy's Avatar
Default Re: Boosting issues. (erknjerk151)
AAHHH he abandoned hos post and people want to know how he fixed it. i bet he just adjusted his wastegate.
rob
Old Oct 28, 2002 | 06:39 AM
legendboy's Avatar
oh, I installed a new T from the local parts store for my BTM. It was one of thoes T's that have the 3 levels of diameter on each leg. I didn't cut off the smaller openings and make the hole bigger for my bigger wastegate hose so the wastegate was basically runnning unlimited boost cause it wasn't getting enough pressure through to actuate it. I cut the small tips off and vola! 10psi
Old Oct 28, 2002 | 08:45 AM
TeStUdO's Avatar
next step for you 1:intercooler, 2:ditch the deltagate for a tial, or say peace out to the rings
Old Oct 28, 2002 | 10:45 AM
legendboy's Avatar
Default Re: Boosting issues. (00si5)
I'm one of thoes people who think deltagates are ok. Just hook them up right.
turbo1.5
Jan 16, 2008 04:47 AM
ragethemachine86
Aug 14, 2006 01:25 PM
RotiEatter
Jun 5, 2004 10:00 AM
tegasaurus
May 28, 2003 01:48 AM
stizzit
Jul 18, 2002 06:10 AM
