Boosting B18c5 Type-r HELP!!!!
Old Apr 20, 2007 | 06:20 AM
eg8b18c's Avatar
Default Boosting B18c5 Type-r HELP!!!!
Is boosting a B18C5 Type -R a good idea?
I dont plan to lower the compression for now . just 4-5 psi with stock internals ( is it safe????)
would Greddy e-manage work on p73 ecm . i already have a GT2840 turbo , thats a good turbo right?
later i will do the internals and run 12-14 psi with S300 .
Some help from u guys plz ! ! !'
Old Apr 20, 2007 | 06:42 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Boosting B18c5 Type-r HELP!!!! (eg8b18c)
flame on, but goodfellas type r was dragged with the fmu for 5 years. 3 of which it had stock internals. the engine was built for higher boost with internals, and some ******* stole it. he ran 7-8 psi for 5 years.
Old Apr 20, 2007 | 07:59 PM
urbansi's Avatar
Default Re: Boosting B18c5 Type-r HELP!!!! (boostedcivicsir)
But not only does the thought of every setup being differnt but also the fact that the car had forged internals that could take the detonation of his AFC hack, but also no one knows how hard the car was beat on as well as the ARF's the car expierenced as well as the timing. freak case if u ask me. Then again i am drunk and kinda in the **** talking mood
Old Apr 20, 2007 | 08:44 PM
95dc2teg's Avatar
Default Re: Boosting B18c5 Type-r HELP!!!! (urbansi)
as long as u get a good tune u should be good with 7lbs on that turbo (maybe more) without a problem. it all depends on how good the tune is, especially so on high compression motors.
Old Apr 21, 2007 | 06:18 AM
still_slow's Avatar
I am boosting my typeR right now I didnt want to chance the 11-1 compression with boost so I put a thicker headgasket.
Old Apr 21, 2007 | 08:43 AM
PrecisionH23a's Avatar
ITR's are fun to boost. They spool fast and make killer power. You just have to be a little careful with the compression... but you can counter that of course with tuning and running a little less timing to keep your peak cylinder pressures down.
You can run 7-8psi all day long on a good tune You can run more of course, it just depends on what you 'want' out of the set-up.
Old May 7, 2007 | 07:02 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Boosting B18c5 Type-r HELP!!!! (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by still_slow &raquo;</TD></TR><TR><TD CLASS="quote">I am boosting my typeR right now I didnt want to chance the 11-1 compression with boost so I put a thicker headgasket.</TD></TR></TABLE>
Where did you get the thicker headgasket?
Old May 7, 2007 | 07:18 PM
W O T's Avatar
Default Re: Boosting B18c5 Type-r HELP!!!! (JDM_Ej)
Cometic makes some nice aftermarket ones, or just stack 2 oem honda's
Old May 8, 2007 | 07:36 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: Boosting B18c5 Type-r HELP!!!! (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">Cometic makes some nice aftermarket ones, or just stack 2 oem honda's</TD></TR></TABLE>
I've heard Cometic is good... stack two OEM ones? Will that seriously work?
Old May 8, 2007 | 10:09 AM
SiTR's Avatar
Im saving up for boost on my ITR. But its been rebuilt for the fact that i spun two bearings so now im running wiseco 9:6 flat top pistons. Didn't really want to destroy an R by lowering the comp but at least know i can boost more.
eg6king!!!
27
Dec 16, 2011 05:48 PM
eg8b18c
Dec 22, 2006 10:29 PM
the jdmchop
Feb 29, 2004 01:48 PM
ItzTw
Apr 24, 2002 01:12 PM
TurBoXBirD16
Jan 25, 2002 04:36 PM
