Boosted S2K
Old Jul 5, 2004 | 07:38 PM
  #26
m R g S r's Avatar
Default Re: Boosted S2K (JD95hatch)
Looks great, did you do it all yourself?
Old Jul 5, 2004 | 07:44 PM
  #27
Mase's Avatar
Default Re: Boosted S2K (Spankee2K)
yup i dunno why they risk such expensive motors w/ bandaid engine management solutions...
Old Jul 5, 2004 | 08:36 PM
  #28
White Smoke's Avatar
i my honda
Global Mod
Default Re: Boosted S2K (Mase)
Sick S200k, treat her right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">yup i dunno why they risk such expensive motors w/ bandaid engine management solutions...</TD></TR></TABLE> Il second that one. Still havent gotton any good answer I would say its just less work for them?
Old Jul 5, 2004 | 08:56 PM
  #29
vaporboy12's Avatar
i mean the that set up should make great power seen a few of the inline s2k kits very clean
Old Jul 6, 2004 | 03:21 AM
  #30
Frozen E's Avatar
H-T White Ops
Default Re: (soccaian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian &raquo;</TD></TR><TR><TD CLASS="quote">wow... you suck at reading</TD></TR></TABLE>
Bite me. I saw pictures and left it at that. Plus it was late. Remember I have 4 hours on you east coast people.
Old Jul 6, 2004 | 06:01 AM
  #31
Turbocivic94's Avatar
Default Re: (IslandSi)
Nice looking S2K. I would definetly look into EMS.
Old Jul 6, 2004 | 07:55 AM
  #32
Rocks
Guest
Posts: n/a
Wow dude . Good job .
Old Jul 6, 2004 | 09:55 AM
  #33
XDEep's Avatar
ya with only the afc your ignition is un-tuned. don't do that to your motor. you've spent all that money and skimped on the most important part..
Old Jul 6, 2004 | 10:27 AM
  #34
darkdayz's Avatar
Default Re: (Spankee2K)
yeah those guys at inline pro are the best they do things with hondas that you could'nt believe like running that much boost on the stock bottom end,Car looks damn good
Old Jul 6, 2004 | 01:54 PM
  #35
Spankee2K's Avatar
Default Re: Boosted S2K (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Looks great, did you do it all yourself?</TD></TR></TABLE>
Acura Technician by day and slacker by night....haha, yeah I did it all myself. It wasn't too bad, hardest part was the headgasket. S2K heads arent as easy as B-series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XDEep &raquo;</TD></TR><TR><TD CLASS="quote">ya with only the afc your ignition is un-tuned. don't do that to your motor. you've spent all that money and skimped on the most important part..</TD></TR></TABLE>
I will eventually go EMS when I want to run 18+ lbs, AFC tuned right is pretty safe also. We never had any problems with it.
Old Jul 6, 2004 | 10:11 PM
  #36
XDEep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spankee2K &raquo;</TD></TR><TR><TD CLASS="quote">
I will eventually go EMS when I want to run 18+ lbs, AFC tuned right is pretty safe also. We never had any problems with it.</TD></TR></TABLE>
even if there aren't any apparent effects, the unnecessary wear and tear on the motor will be there. you may not be able to see it, but basic engine and turbo theory prove this. not to mention the power loss. i guess if you think the motor is that strong and economically viable then its not much of an issue.
there is this analogy which states that one run down the quarter mile is similar in engine wear to 1000 street miles. just imagine the 24 hours of le mans..
Old Jul 7, 2004 | 12:30 AM
  #37
99blackcivicSi's Avatar
Because that is all they know how to use...i mean hell they can HARDLY get by with tunning the Vafc let along something that requires accually learning and work to do
Old Jul 7, 2004 | 04:12 AM
  #38
USDM 4G VTEC's Avatar
Default Re: Boosted S2K (99blackcivicSi)
i love the car, love ur setup and wich u the best luck
but i hate the location of that BOV
they are suposed to be somewhere arounf 12-16 inches away from the throtle body butterfly... i dont like the fact all tha pressurised air needs to back up all the way back to that point in order to Blow off....
but thats just IMO.... hopefully that way works without problems
Old Jul 7, 2004 | 05:24 AM
  #39
1bar's Avatar
Default Re: Boosted S2K (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
but thats just IMO.... hopefully that way works without problems</TD></TR></TABLE>
it will
Old Jul 7, 2004 | 06:38 AM
  #40
XDEep's Avatar
fyi the full race bov is mounted on the ic, intended to be as close to the compressor as possible.
Old Jul 7, 2004 | 08:40 AM
  #41
Chris99SI's Avatar
off the hook
Old Jul 7, 2004 | 09:24 AM
  #42
Default Re: Boosted S2K (XDEep)
fyi the full race bov is mounted on the ic, intended to be as close to the compressor as possible.</TD></TR></TABLE>
well like i posted... IMO..... all the books about turbos i have read, and many other tuners have told me so..... thats why i am basing my info on, and thats why i did it like that on my setup also...
but hey.... on their case, it might work better for that setup.......
Old Jul 7, 2004 | 05:04 PM
  #43
XDEep's Avatar
but hey.... on their case, it might work better for that setup.......</TD></TR></TABLE>
corky bell doesnt go into timing?
Old Jul 8, 2004 | 06:08 PM
  #44
Ri5e's Avatar
The car made 320 RWHP @ 14 PSI I believe? With a slipping clutch ... very impressive if you ask me, with just injectors and S-AFC, NO FMU!
Old Jul 8, 2004 | 06:10 PM
  #45
alpha's Avatar
Default Re: Boosted S2K (BG Boost)
This motor had to of made more than 320whp @ 14lbs. Can the original poster confirm?
Old Jul 8, 2004 | 07:35 PM
  #46
Spankee2K's Avatar
Default Re: Boosted S2K (0x64)
It made 320hp on 12psi and 240 torque in 3rd gear. The clutch was slipping at 7K rpm in fourth gear so the run was made in 3rd gear which nets 15-20hp difference. The boost for some reason didnt hold 14psi steady to redline, it would hit 14 then drop to about 10-11 at around 6500rpm. After I get a new clutch in and fix the boost problem it should have no problem reaching around 375hp. Yes the clutch is stock.
Old Jul 8, 2004 | 07:38 PM
  #47
Spankee2K's Avatar
The A/F ratio was good also, around 12:1 13:1 until the boost dropped off which then it went down around to 10:1. Ahhh...the problems of boost come back to haunt me! Other than that, its a beast on the street, no tire spinning since it has massive traction being RWD.
Old Jul 8, 2004 | 07:39 PM
  #48
Todapwr's Avatar
Old Jul 8, 2004 | 07:48 PM
  #49
uptownrickyv's Avatar
Whoa!
millsd4
Apr 8, 2009 04:29 AM
themurrell
Apr 7, 2007 05:55 PM
vegaskurt
Feb 18, 2005 03:29 PM
tyrone27
May 22, 2004 10:58 PM
