what size turbo for my 2.0 type r street motor
i need help findin what turbo should i get for my motor. i have a 99 type r block with darton sleeves,84mm arias pistons at 9.8.1 with a fully port and polished head and aem stand alone. this is a daily driven car and i want to make 350 to 400 hp on pump gas. the most ill ever get to is 450 TOPS. My prob is i wanna make it on low boost cause i dont wanna have to run 18 plus pounds to get there. how can i get 350 to 400 hp with low boost like say 12- 15 psi on the strret with out a ton of lag. i know its a lot sorry but im confused. i see so much different stuff like a gsr with 372 hp on 9 psi with a sc61,then i see colin from rpm nyc makes 450 on 14psi with a 62-1 so where do i fit in with my set up . are these just high horsepower motors with a ton of lag? im sorry for ramblin on but any help would be greatly appreciated thanks a lot guys. please help me . also i would prefer a t3 turbine cause it will fit my manifold. is it possible to make 350 plus on low boost with little lag or am i dreamin. thanks soooo much for any help
WEST COAST
Re: what size turbo for my 2.0 type r street motor (hotasscivic)
MODEL: T3/60-1S $750 + Shipping
COMPRESSOR HOUSING/TRIM: TO4S/ 60-1 Wheel
EXHAUST FLANGE and .AR: T3/ .63
EXHAUST WHEEL STAGE: Stage 3
Yeah I'm putting a my SC61 on my new block in a couple of weeks. With a 2.0L lag shouldn't be that bad I would go with that.
Re: what size turbo for my 2.0 type r street motor (DBallz)
What rpms are you gonna start making boost? and at what rpm do you guys hit full boost on say a Gsr block? with the 60-1
Re: what size turbo for my 2.0 type r street motor (Spooled1.6L)
i'm got an innovative gts61, same as an sc61, for my 2.0 16v VW motor, i can get you a new one for a smoking price, pm me if interested
60-1 and a log style manifold you will have spoolup at 4500 and you will be fully spooled up at 5500
with a tubular style manifold like the full race you will be fully spooled up by 4600-4800 area..
Talk to art....
The PTE SC61 w/t3 extaust housing, stage 5 exhaust wheel, and either the t04E or S compressor housing... You won't be dissatistfied with it...
sleeving a block for 450hp seems like a waste.
btw, get advice from Ppl that have DONE IT and USED these turbos on their cars.
Re: what size turbo for my 2.0 type r street motor (Bulldogg83)
I also reccomend the gt35e from precision. The GT turbine wheel is said to spool a bit faster and free up some power. You wont be dissapointed with the sc61 or the gt35e. Arturbo is the man to speak to. He is very helpful! CHRIS
Re: what size turbo for my 2.0 type r street motor (Mpir3)
cause i thought that running high boost on pump gas was bad, at least i thought it would be better to run low boost cause of too much heat but i dont know thats y im askin you guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotasscivic »</TD></TR><TR><TD CLASS="quote">cause i thought that running high boost on pump gas was bad, at least i thought it would be better to run low boost cause of too much heat but i dont know thats y im askin you guys</TD></TR></TABLE>
boost is not hard on motor. power is hard on motors, more or less.... anyway, i vote sc61 either way. $667 from tony @ import-palace.com, hes a good guy.
GSRinmyCRX
11-21-2012 04:08 AM
