Cleaned my fitv and now my car revs by itself.
Last night I cleaned out my fitv and tb and installed a new tb gasket. I put everything back together and now when I start my car it revs to 5k and stays there.
I checked codes and brought up a 10 and a 1, IAT and 02 but those have been there.
All the hoses are on, emissions, vacuum, coolant.
I took the throttle cable off of the tb so there isn't an issue there. The idle screw is in its origional position.
Im just trying to brainstorm on things I may have missed, help me out!
I'm not Rick!
Re: Cleaned my fitv and now my car revs by itself.
weird..................
is your tps sensor on all the way...did you take that off?
is the butterfly stuck at all?... you must have a BDL TB lol
The butterfly is at idle position not stuck at all. BDL?
I really wish I knew what was wrong I'll have to take it off and take everything apart again tomorrow morning.
if u plug up the lower hole in the tb opening that goes to the fitv does the idle go to normal? that's a quick easy way to figure out if it has anything to do with the fitv.
Make sure your IACV has a good connection you may clean it 2. My car did that when my IACV had a bad plug
Ok today I took it off again and used a different fitv and still the same problem. I'm stumped, maybe it has nothing to do with the tb and it was just bad timing that i had another problem?
That sounds like a TPS issue. Right now my TPS is broken so I can't put the plug on. When I start my car it revs to 3k and gradually goes higher.
Changed tb and fitv with a different tb/fitv and still does it.
Reset ecu and now it fluctuates from 2 - 3k rpms.
Still throwing IAT check engine code.
I left out before that it makes a loud whining noise while it runs.
Did you use the same TB gasket? maybe the old one is damaged or you didnt put it on right and its causing a vacuum leak, happened to me once my TB gasket i put on upside down and it surged from 2-3k rpm and made the whining noise your talking about.
I'm just going to take the whole intake manifold off tomorrow and check for the leak
Problem: Idle at 5k+ rpms on start up, whining noise coming from engine bay.
Before: Cleaned out TB and FITV with simple green. Put back on with new oem honda TB gasket.
(Problem)
After:
Replaced TB/FITV with a spare.
Replaced EACV with a spare.
The problem changes to fluctuating idle(2200-2800) after ecu reset. It is somtimes hesitant around 2200.
There is a still a whining noise.
There is still smoke coming from exhaust manifold, it smells like its running horribly rich.
Facts:
Throttle cable detached to ensure it is not a throttle problem.
Thottle body plate is at idle position.
Any ideas HT??
(Problem)
After:
Facts:
Any ideas HT??
