Boosted GSR problems
Old Jan 28, 2005 | 08:57 AM
  #26
t04ecvc's Avatar
Default Re: Boosted GSR problems (Integra21)
Check the gapping on your plugs also. The missfire could be a combo of things, but usually its the plugs being crappy or gapped too big. If your motor only has 15k miles, its prob not the rotor etc ( unless its not factory honda parts). If the plugs don't fix the problem, i would progress to the rotor, cap etc because they aren't expensive to replace. Alot of guys do just fine with the factory ignition. There are 400whp cars running around on the stock stuff.
Old Jan 28, 2005 | 09:21 AM
  #27
IS3Fifty's Avatar
Default Re: Boosted GSR problems (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">
You should check out Uberdata...here are some price comparisons for UD vs Hondata.
UBERDATA
$55-$85 Willem burner on http://www.ebay.com or BURN1 burner http://www.moates.net
$15 http://www.moates.net UBER1 ecu chipping kit (everything you need to chip your ECU)
$25 send your ECU to moates and they'll install the UBER1 kit for you
$2-$15 Cell phone data cable--solder it into your ECU to make allow it to datalog moates might do it for you too
$330 PLX 300 wideband O2 kit--you can use any WB setup, this is the one I'm getting
HONDATA
$495 - Hondata S200 with boost option
$25-$85 to pay somebody to chip your ECU
$330 PLX 300 WB O2 kit
That's a rundown of how much it would cost to get each system. In both cases you'll probably want to get bigger injectors, a better ignition system and also some dyno tuning. If you want more info on Uberdata check out the links in my sig.
Neptune over Hondata!!! http://www.evans-tuning.com
Old Jan 28, 2005 | 10:38 AM
  #28
Integra21's Avatar
keep them coming - how much would a good dyno tuning session cost??
any good places in tampa? secret services? central florida turbo?
Old Jan 28, 2005 | 01:03 PM
  #29
Integra21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">keep them coming - how much would a good dyno tuning session cost??
any good places in tampa? secret services? central florida turbo?</TD></TR></TABLE>
any one know?
Old Jan 28, 2005 | 04:45 PM
  #30
Dunc's Avatar
BCICAN
depends on how well tuned you want your car. If you want part throttle as well, it will obviously be more than just tuning under WOT. Also, if you want the ignition fine tuned as well it will take more time. I would say that a shop should be able to do a full tune within like 3-4 hours. Well at least that's about how long I usually take.
Old Jan 28, 2005 | 07:14 PM
  #31
Integra21's Avatar
Default Re: Boosted GSR problems (Dunc)
whats a ballpark for a good tuning session? im in the dark here thats why im asking
Old Jan 28, 2005 | 07:28 PM
  #32
PyroProblem's Avatar
Some engine management and a WB O2 sensor will solve any tuning problems, if thats the case...
If its mechanical (Fuel pressure,bad ignition system,low compression) then obviously it wont. I would get a WB o2 sensor kit and see how your fuel is looking. Probably not it since it should throw o2 sensor thresholds faults as well...
I live here in Tampa also and supposedly everyone makes the trip to Gainsville (i think) to see a tuner called Mase...
Old Jan 28, 2005 | 07:35 PM
  #33
Integra21's Avatar
Default Re: Boosted GSR problems (PyroProblem)
i just emailed CFT and am trying to find the web site for secret services in st. pete
Old Jan 28, 2005 | 09:23 PM
  #34
SdGSR01's Avatar
Man I had the same exact problem. I tried everything, the car ran fine but the CEL always came on. Switched to Hondata S200B and now its all better, haven't had a CEL since. Bue box sucks.
Old Jan 29, 2005 | 07:24 PM
  #35
Integra21's Avatar
Default Re: Boosted GSR problems (SdGSR01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SdGSR01 &raquo;</TD></TR><TR><TD CLASS="quote">Man I had the same exact problem. I tried everything, the car ran fine but the CEL always came on. Switched to Hondata S200B and now its all better, haven't had a CEL since. Bue box sucks.</TD></TR></TABLE>
PM'ed ya
Old Jan 30, 2005 | 12:46 AM
  #36
PIC Performance's Avatar
I think a typical shop will charge ~$100 per hour for tuning.
Old Jan 30, 2005 | 06:37 AM
  #37
Integra21's Avatar
Default Re: Boosted GSR problems (Noob4life)
thats FI guys - hope this fixes it!
Old Jan 30, 2005 | 12:46 PM
  #38
Integra21's Avatar
Default Re: Boosted GSR problems (t04ecvc)
bump
Old Jan 30, 2005 | 04:22 PM
  #39
Integra21's Avatar
anyone else?
Old Jan 30, 2005 | 06:11 PM
  #40
Integra21's Avatar
Old Jan 31, 2005 | 11:50 AM
  #41
SdGSR01's Avatar
Just IM'd you back, sorry for the hold up
Old Feb 1, 2005 | 05:15 AM
  #42
Integra21's Avatar
thanks for the PM back - im also in the process of contacting CFT and Greddy
Old Feb 5, 2005 | 08:53 AM
  #43
nonvtecD's Avatar
Get Uberdata, my plugs are stock gap and I have been running up to 10 psi on my D15 with no problems.
AnotherSi33
87
Dec 8, 2008 08:42 PM
tabbob7681
Apr 8, 2008 01:20 PM
Squallie
Oct 15, 2005 08:53 PM
Xpos
Nov 8, 2004 06:09 AM
boostedsi1
Apr 30, 2003 05:24 PM
