Boosted F22?
Old Jun 4, 2003 | 05:36 PM
bluedelsol's Avatar
Default Boosted F22?
What would i expect out of an F22b1 with a small turbo on it running like 10-12PSI?
And what is the max psi i can run on this engine?
The specs of the engine are:
F22b1 2.2L
8.8:1 compression
HP: 145@5500 RPM
Torque: 147@4500 RPM
Old Jun 4, 2003 | 05:45 PM
TeStUdO's Avatar
youll probably just blow it and not be able to pay for a rebuild with your GED
https://honda-tech.com/zerothread?id=522327
NOTE: KIDS STAY IN SCHOOL!
Old Jun 4, 2003 | 05:51 PM
bluedelsol's Avatar
Default Re: (TeStUdO)
Oh, you a ****** Comedian, thats great.
Old Jun 4, 2003 | 05:53 PM
TeStUdO's Avatar
well what kind of fuel management are you gonna be running? what turbo? have you even done any research on this?
Old Jun 4, 2003 | 06:00 PM
bluedelsol's Avatar
well, your finnaly gona help me. thanks
it's a turbo from a 1988 Mitsubishi Starion. it max's out at 10 psi according to seller. not shure on the exact specs. i have an fields sfc controller, 450cc injectors. and will be running a homemade boost controller that comes with the turbo and an eclips BOV. what do you think?
Old Jun 4, 2003 | 06:04 PM
Broken Gearbox's Avatar
Default Re: (bluedelsol)
...i think you should it
just tune it right.
Old Jun 4, 2003 | 06:05 PM
TeStUdO's Avatar
i think you have no fuel management and there is no way you are gonna be able to run 10lbs. safely. i assume the turbo is internally gated and probably a t25 or t28? youll make boost really early with that small of a turbo, id look into some fuel management and tuning before i went turbo
Old Jun 4, 2003 | 06:06 PM
bluedelsol's Avatar
Default Re: (Powered By D15)
ok, the turbo is a td05.
bluedelsol's Avatar
what kind of fuel managment should i look into?
Old Jun 4, 2003 | 06:08 PM
TeStUdO's Avatar
hondata, or something along those lines
Old Jun 4, 2003 | 06:09 PM
bluedelsol's Avatar
what honda data should i get? the s200?
Old Jun 4, 2003 | 06:12 PM
TeStUdO's Avatar
s200b, with at least datalogging. do some more research. try the search button before you decide to do something like throwing a turbo on your car
Old Jun 4, 2003 | 06:20 PM
bluedelsol's Avatar
what kind of hp do you think i would get with this setup and an s200?
Old Jun 4, 2003 | 09:24 PM
Blaze45's Avatar
Brrraaaap!
I think that it depends on how much boost you run and how well you tune it.
Blaze
Old Jun 5, 2003 | 07:23 AM
bluedelsol's Avatar
Default Re: Boosted F22? (bluedelsol)
what times do you think i could run? do you guys thing i could hit 250HP with good tuning
Tjabo
Mar 10, 2009 10:39 AM
QwkD16
May 14, 2006 09:17 PM
kr
Sep 3, 2004 03:40 PM
Briman2021
Oct 28, 2003 08:34 AM
