Boosted D16Z6
Old May 25, 2009 | 06:33 PM
toolbox21's Avatar
Default Boosted D16Z6
Im boosting z6 with stock internals and im using a dsm 14b turbo, i was wondering how much boost i can run with that turbo with stock internals. another ? what can stock sleeves handle as far as boost?
Old May 25, 2009 | 07:28 PM
95civhb's Avatar
Default Re: Boosted D16Z6
the general rule of thumb is less than 200hp on a stock bottom end..
stock sleeves can handle 400-500 .. look around on the forum ..
14b's are good for 200-250 depending on supporting mods..
Old May 25, 2009 | 07:41 PM
mattyfo0z's Avatar
Pretty much what 95civhb said.
I'd do a compression test before you decide to boost to make sure your motor is in good, working order so you can save yourself the hassle of a blown up engine after an hour of fun with boost.
Old May 25, 2009 | 08:20 PM
Mr.Death's Avatar
I'd say you could run 11 lbs with that turbo no probs with a good tune. Maybe 195-220 hp.
Old May 25, 2009 | 08:49 PM
912's Avatar
912
250hp easy with that turbo get dsm bov 450cc from talon and eliminate that stock elbow run at least 2.5 or 3 inch dp front mount good base map or tune also get cdm mani cast with t25 flange you should be around 250 at 10 plus psi
lilshady6796
Sep 5, 2009 08:13 AM
themurrell
Apr 7, 2007 05:55 PM
themorphious
May 30, 2006 02:48 PM
hondaboy92
Apr 16, 2005 07:39 AM
X2BOARD
Jun 18, 2003 10:14 AM
