Boost spikes (overboost?????) question. HELP
Old Jul 22, 2002 | 08:22 AM
austrian type-R's Avatar
Default Boost spikes (overboost?????) question. HELP
Is this Overboost or boost spikes?
I have the Greddy profec B and setted it to 1.2 Bar. It is pretty cool holding 1.2 Bar in all driving conditions, but when I hold the throttle in a sertan position, so that the turbo spool realy loud and sligtly boost about 0.2 Bar and then suddenly WOT, boost rush up to 1.6 Bar for a few thents. I have adjusted the balance **** all the way left, but I get the same results minus having slower spool up time.
Should I put the jumper position (rear side of the Unit) on the "over-boost occurs" position? Or is it just normal with such kind of an boost controller and I have to take care of this boost climbing.
Old Jul 22, 2002 | 10:45 AM
SiRkid's Avatar
Default Re: Boost spikes (overboost?????) question. HELP (austrian type-R)
sounds like boost spike to me
[Modified by SiRkid, 7:45 PM 7/22/2002]
Old Jul 22, 2002 | 12:54 PM
Default Re: Boost spikes (SiRkid)
so, do I need an other kind of manifold to get more exhaust gases to the waste gate?
Old Jul 23, 2002 | 12:24 AM
Default Re: Boost spikes (austrian type-R)
ttt
Old Jul 23, 2002 | 05:12 AM
turbotypeR@SPEC's Avatar
25 Year Member
drag manifold is bad about boost creep.when i had one,i could not make less than 18lbs.now that i have the wastegate off of the turbine housing(downpipe flange),i can turn it down a good bit and it goes to the boost i set it at and stays there rock solid.
Old Jul 23, 2002 | 05:40 AM
Default Re: Boost spikes (turbotypeR)
hmm, can you describe this more accurate, I don't get it. You could not make less than 18lbs???? Where did you had the wg and where is it now, what manifold are you using now?
Old Jul 23, 2002 | 07:17 PM
25 Year Member
yeah,once i got 3" down pipe apexi ic and larger ic piping,it was flowing too good.the fact that the wastegate was on one cylinder allowed the pressure to pass the wastegate.i made a manifold myself (it rocks by the way).it has no port for the wastegate.the wastegate is fed from a hole in the downpipe flange and lines up with the original wastegate hole.it works great.
austrian type-R
Mar 6, 2003 10:37 AM
turbopanda
May 24, 2002 01:42 PM
austrian type-R
Mar 14, 2002 07:11 PM
Boostin Si
Jul 28, 2001 11:47 AM
