boost spike?
Old May 2, 2008 | 11:19 AM
1fastlude1's Avatar
Default boost spike?
i cant figure it out, i have a 5 psi spring and it is boost spikeing to 13-15 psi i dont see a hole in the dia., or vacuum line, and i can hear the waste gate open, wtf please help
Old May 2, 2008 | 11:22 AM
slotec's Avatar
Default Re: boost spike? (1fastlude1)
possibly too small of a wastegate, manifold design, location of your wastegate line (instead of running it to the intake manifold run it to the turbo compressor housing)
Old May 2, 2008 | 11:27 AM
1fastlude1's Avatar
Default Re: boost spike? (slotec)
the line is on the compressor, im also thinking the wg is too small but need some advice thinks
CarterRace.com's Avatar
We need more info on your setup - what manifold, turbo, wastegate, motor, etc and then we can help you.
Old May 2, 2008 | 11:33 AM
1fastlude1's Avatar
Default Re: (CarterRace.com)
ram horn manifold, tial wg, t3/t4, h22
Old May 2, 2008 | 11:58 AM
dpetro1's Avatar
Default Re: (1fastlude1)
are you spiking or just overboosting. spiking would mean that boost initially shoots up to but then comes back down to normal. boost creep is when you hold steady for a while but then slow rise as the rpm increases. if the wastegate isnt regulating boost at then you are overboosting and there must be a problem.
any pics of the set-up cause your decription is pretty vague. is your vacuum line going from the turbo to side port of wastegate? are you sure you dont have a bigger spring? (maybe 1 bar)
Old May 2, 2008 | 01:32 PM
1fastlude1's Avatar
Default Re: (dpetro1)
i meant creeping sorry, it hits 5 and stays for a second till about 5300rpm, i have the line coming from the compressor to the side of the wg and im sure it a 5psi spring, sorry no pics
Old May 2, 2008 | 01:40 PM
dpetro1's Avatar
sounds like wg is too small or positioned poorly
pv2dickman
May 27, 2005 05:59 PM
B16CRXT
Apr 24, 2005 07:50 PM
turbodohcsi
Jun 3, 2004 11:02 PM
Nextelbuddy
Mar 26, 2004 01:20 PM
Cowboy
Jun 16, 2003 02:12 PM
