boost solenoid problems
Old Sep 13, 2008 | 05:27 PM
dreadcivicturbo's Avatar
Default boost solenoid problems
currently trying to use a gm solenoid with s300. have it wired as followed, one wire to a11 and the other to +12 volt source. the problem is everytime i turn on the ingniton the solenoid gets activated no matter what i set the solenoid activation to. the gm solenoid is a normally open solenoid, but i have tried it both open and close with no luck. took the ecu to a reputable shop today and have it inspected, everything checked out fine. not sure what it could be this is the second solenoid that i have tried.
Old Sep 13, 2008 | 08:55 PM
narfdanarf's Avatar
Default Re: boost solenoid problems (dreadcivicturbo)
I had the same problem and I had to had to put a new q20 transistor in it.
Old Sep 14, 2008 | 09:19 AM
Turbocivic94's Avatar
Default Re: boost solenoid problems (narfdanarf)
I hope that works man
Old Sep 14, 2008 | 01:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narfdanarf &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem and I had to had to put a new q20 transistor in it.</TD></TR></TABLE>
going to give that a try
Old Sep 14, 2008 | 01:13 PM
SOHC_MShue's Avatar
is it pulsing like it should or is it going all the way closed when you turn on the ignition? I had one ecu that did this to me. Never could figure out what it was. It would just pull a ground to it no matter what.
Old Sep 14, 2008 | 01:27 PM
TheWickedOne's Avatar
Use the least amount of heat to those components.. preferrably a 15 watt Iron or a temp controlled unit. and if switching the transitor does not work, then you'll have to get another ECU.
Old Sep 15, 2008 | 05:44 PM
Default Re: boost solenoid problems (SOHC_MShue)
its not puslsing, it closes all the way soon as i turn on the ignition on. i ordered the transistor today so i'll see what happens.
Old Sep 29, 2008 | 08:45 AM
problem fixed...bad transistor in the ecu
EARLdaSQUIRREL
Engine Management and Tuning
19
Apr 21, 2009 07:15 PM
Top Ramen
Jun 14, 2008 05:12 AM
B18EG6
May 16, 2008 08:02 PM
LeesB
Sep 27, 2004 06:47 AM
ViXoN Hatch94
Jul 22, 2004 07:26 AM
