Boost Problems.?
Old May 21, 2009 | 10:34 AM
madracer's Avatar
Default Boost Problems.?
Hi Guy's,
I have a friend that just found a problem in his Boost set-up.
He has a B18B1 on boost with 8-psi, using a Autometer boost guage, knock-off Greddy type blow-off-valve and a Tial 44mm wastegate. The problem he notice was he came to my house yesterday and the car was boosting 8-psi using vaccum from the turbo but the top of the wastgate had a bolt covering the vent hole of the wastgate which I think should be open to atmosphere if you not using elcetronic boost controller. So he remove the bolt from the top of the wastegate and left it open then when he left to go home the would only boost up to 5-psi. He then put back the bolt on thop off the wastegate and drove the again but he had the same problem 5-psi. Could you guy's recommend any help as to what might be the problem.????
From 8-psi boost to 5-psi boost on its own, its crazy . It have me puzzle, why it wont boost back up to 8-psi of boost.???
Thank you for any help you can offer.....
Old May 21, 2009 | 11:31 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Boost Problems.?
boost leak?, piping, couplers, etc
Old May 21, 2009 | 02:36 PM
madracer's Avatar
Thanks for your help, I will let him know that and taught the same thing you mention but i did not think about the couplers/piping....
Thanks alot...
rudebwoy
Mar 17, 2007 12:53 PM
B_1_8_hatch
Oct 6, 2003 12:01 AM
DIRep972
Nov 26, 2001 07:57 PM
