Boost problem
Old Oct 10, 2005 | 04:38 PM
Quickgti1.8t's Avatar
Default Boost problem
I was wondering if you honda guys have this problem. It really ****'s me off. Heres a vid of it. It only does it over 21psi. It makes a flutter sound under full boost from the air filter.
http://www.we-todd-did-racing....5NTQx
some people said it could be from my ball spring MBC I know most of you have more experiance so thats why im asking
Old Oct 10, 2005 | 04:43 PM
a1320addict's Avatar
Default Re: Boost problem (CashmoneyUKR)
what are the specs on the turbo? if youre pushing it out of its efficiency range...you might be hearing the "pigeons" aka compressor surge.
Old Oct 10, 2005 | 04:53 PM
Default Re: Boost problem (yehiknowrite)
t3/t4 57 trim .63 a/r stage 3 wheel. garret turbo.
Old Oct 10, 2005 | 05:17 PM
adseguy's Avatar
I'd say it's your MBC, your wastegate spring is too small (only 2x the boost should be used), or improper vaccum source (to many things connected to a single vaccum source)
Old Oct 10, 2005 | 05:35 PM
Default Re: Boost problem (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">I'd say it's your MBC, your wastegate spring is too small (only 2x the boost should be used), or improper vaccum source (to many things connected to a single vaccum source)</TD></TR></TABLE>
I have a 1 bar spring in the tial 38mm already. I dont have anything T'ed. I barely have any vacuum lines. 1 is T'ed off to the MBC, all the other run from the intake mani. in separate lines. I bought a 7psi spring from here so im going to add to my 1 bar spring should put me close to 22psi. Hopefully that fixe's it
andrew1320
Feb 23, 2012 07:13 AM
fasterthenU
Sep 14, 2007 12:06 AM
ivt-t
Apr 21, 2007 06:13 PM
b18cEF9
Jul 31, 2005 10:56 AM
