Boost pressure levels
Old Jan 14, 2006 | 03:25 PM
tmramsburg's Avatar
Default Boost pressure levels
I have:
D16y7
T25
DSM eclipse side mount intercooler
JDM Integra Type R injectors
12:1 FMU
My question is, how much boost can i run safely on the fuel setup? I have been at 5psi for about a year now.
Old Jan 14, 2006 | 03:43 PM
rainmanEK's Avatar
big strong guy
Default Re: Boost pressure levels (tmramsburg)
That FMU ratio is kinda High
I just finished a similar setup and its running 7psi, though with a 6:1 fmu and stock SOHC injectors!
Eric
Old Jan 14, 2006 | 04:06 PM
Jared's Avatar
no level of boost is safe with an fmu and stock injectors. just consider yourself lucky if it has lasted that long.
Old Jan 14, 2006 | 04:07 PM
PnkRokCountryboy's Avatar
Default Re: (Jared)
yeah no ****, +1^
Old Jan 14, 2006 | 04:25 PM
TurboCoop's Avatar
Default Re: (PnkRokCountryboy)
+2^^
Old Jan 14, 2006 | 04:34 PM
tmramsburg's Avatar
1998 JDM INTEGRA TYPE R INJECTORS. I said nothing about stock injectors for a d16y7.
Old Jan 14, 2006 | 04:47 PM
Zakar's Avatar
you could run Uberdata.. your stock map sensor is 10psi max..
bring it to a place and have them tune the uber on a wideband.. they will likly run the highest pressure possible on pumpgas..
do a search of shops around your area that have a good rep here on HT.. call them.. check out your options
ARACER25
Aug 4, 2003 06:21 PM
GOLDBERG
Apr 13, 2003 05:16 PM
94hondaLS
Mar 20, 2003 02:12 AM
Rah Rah
Feb 24, 2003 06:03 PM
Giuseppe
Oct 10, 2001 09:23 PM
