Boost over 12psi with stock ecu?
Old Feb 9, 2004 | 08:39 PM
mogz's Avatar
Default Boost over 12psi with stock ecu?
I have a 00 GSR and I was wondering if my stock ecu can allow me to boost over 12psi or will it give me a CEL?
Old Feb 9, 2004 | 08:50 PM
boosted_dc2's Avatar
Default Re: Boost over 12psi with stock ecu? (mogz)
you cant boost past 11 psi with a stock map sensor. do a search and youll find more information.
Landon
Old Feb 9, 2004 | 09:15 PM
quikB18B's Avatar
Default Re: Boost over 12psi with stock ecu? (boosted_dc2)
Yes it the map sensor which wont alow you to run more boost, youll need to run a 3bar map sensor to bypass this.
Search under "bar map" in Fi archives
Old Feb 9, 2004 | 09:46 PM
TurboR1391's Avatar
You can boost past 11 psi on the stock map sensor if you are using the missing link for the map sensor. I would just go with Hondata to alleviate tuning problems. Before I got Hondata I used a VAFC with a missing link and ran 15psi daily. The car ran fine, but I couldn't really get my stock computer to agree with the VAFC on the dyno.
Old Feb 10, 2004 | 06:22 AM
Joseph Davis's Avatar
Default Re: Boost over 12psi with stock ecu? (TurboR1391)
You can't run 11 psi on the stock ECU - or more specifically the stock MAP sensor. It doesn't read that high.
Old Feb 10, 2004 | 06:51 AM
b20turboic's Avatar
Default Re: Boost over 12psi with stock ecu? (J. Davis)
stock map stops at 10.3 psi i believe
Old Feb 10, 2004 | 07:49 AM
Egg-weezy's Avatar
I can't get pass 8psi on the stock MAP
SnailedEG
Jan 28, 2010 12:52 PM
vy3tnamezz
Sep 1, 2009 07:10 PM
Honda4life777
Jul 6, 2009 09:00 PM
hondamn1320
Apr 3, 2008 05:54 AM
bubbahatch92
Nov 13, 2003 01:03 PM
